Old 05-31-2014, 10:27 PM
Default how can I keep the backlight on at all times?
I set it to Infinite and no light at all I set it to squelch and it only stays on for like 5 seconds or so.. How can I make it on at all times? 1.11.10
Old 05-31-2014, 10:40 PM
bryan_herbert's Avatar
When its set to infinite, you turn it on and off manually with the power button, there's no timer.
Bryan Herbert - KE6ZGP | WQKW261
http://twitter.com/ke6zgp
http://bryanherbert.com
Old 05-31-2014, 10:53 PM
Thanks a lot for the info.. it worked.. Solved
Old 05-31-2014, 11:01 PM
thanks
Old 06-01-2014, 12:30 AM
teufler's Avatar
tHE FILE SENT TO YOU HAS BACKLIGHT AT INFINITE.
WD0GSYDMR ID 3129226 AND 3129304
BC-396XT,780XLT,TENTEC PARAGON, TYT-2017, MD-390, DM-5R+, ANYTONE 5888,VX10, VX7, VX3,TERMN-8R, F8-HP, GT3, UV-5, UV-3R, WOUXUN UV-8D,JUENTAI UV8DR,
