Closed Thread
  #21 (permalink)
Old 07-12-2014, 7:49 PM
Originally Posted by phask View Post
James - possibly an Enc. TG???? I occasionally get a few TG's that will encrypt and I get either a brief digital "noise" or what sounds like a squelch tail, sometimes they stay on screen but are quiet after that initial noise.
I do not think these were Encrypted TG or Encrypted traffic.
It was a bit sporadic so I will need to see if it happens again and try to figure out what is going on.
What can say is most of the systems that the threshold value needs to be in the 10-12 range at times motorboated a bit. With the Beta firmware, this seems to be reduced if not fully eliminated at least for the systems I monitor. So possibly the threshold is faster to capture or something else has been tweaked.
  #22 (permalink)
Old 07-13-2014, 12:41 AM
northzone's Avatar
Greatly improved P25 trunked simulcast audio. Then after a few minutes it receives nothing and signal meter shows no signal. Back to version 2.04 with no other changes and everything works fine. Tried this 3 times always with the same results. Tried all of the different audio settings (auto, manual, filter A, Filter B, offset, no offset).
  #23 (permalink)
Old 07-13-2014, 6:58 PM
tumegpc's Avatar
Default HP-1 Firmware 2.06 vs 2.03 Murata 50E vs 50G
With the new 2.06 beta firmware I wanted to finally spend a few hours testing the HP-1 and also to confirm the results of the Murata 50G filter mod. I had three HP-1s running and using the same antennas,the R/S 800 and an indoor Yagi. I ran firmware 2.06 and 2.03 with HP-1 50E stock filter and 50G Mod. What I found was that firmware 2.03 was the best with both filters.
The HP-1 with the 50G was able to receive the next county's P25 with firmware 2.03 and 2.06 while the other two were silent. This is my second HP-1 with the 50G mod , so that was helpful to see the same positive results.
SCANNERS:
Whistler TRX-1/ TRX-2 - DMR - NXDN supported
Uniden 536HP - DMR - NXDN supported } OMG ! It's about time.
Uniden 325P2 - DMR
  #24 (permalink)
Old 07-14-2014, 8:35 AM
UPMan's Avatar
Uniden Representative
Originally Posted by EricCottrell View Post
Hello,
All three sites I am using to test are on the same system, so I am using one favorites list. I set avoid on the two sites I was not testing. I noticed during testing that the signal would briefly drop to zero every second. I deleted the two unused sites and I get the same result. No other alerts are on. This dropout does briefly affect the auto reading, but the control channel does not seem to dropout as the display still shows DAT.
Is anyone else noticing this during testing?
73 Eric
That is normal. The scanner does some housekeeping between CC checks. You can lengthen the time between these checks by setting a longer Site Hold time. Default of 0 will cycle about every 1.5-2 seconds.
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
  #25 (permalink)
Old 07-14-2014, 10:11 AM
alphaacres's Avatar
If the software logged every hit and was accurate in the database column this would be great for testing
  #26 (permalink)
Old 07-14-2014, 10:35 AM
Hello,
Thanks. Originally I thought it made no difference, but as I noted in the spreadsheet the HP1 had trouble when it came back to check the 700 Overlay site control channel. I will try a longer site hold and see if things improve on the site.
73 Eric
  #27 (permalink)
Old 07-14-2014, 11:10 AM
KevinC's Avatar
Moderator
Hello,
73 Eric
When you find that "Site Hold" setting let me know where it is as I can't seem to find it for the HP-1.
Someone told me signatures are silly, so I got rid of mine.
  #28 (permalink)
Old 07-14-2014, 4:18 PM
Super Moderator
This thread is under strict supervision by us at the request of Paul. Any and all posts not directly related to the topic will be deleted. We've already deleted many posts and I want to reduce that number.
If you have a question it must directly involve the OP or if replying to a member's post that content must strictly involve the topic being discussed. Direct questions about other things should go via email or PM.
To contact me please use the forum email function as I do not accept Private Messages unless you're on my contact list.
All rules and guidelines are covered in this forum. These are required reading for new members and all existing should follow for any updates.
  #29 (permalink)
Old 07-14-2014, 4:33 PM
UPMan's Avatar
Ah, HP-1 doesn't have the site hold time option. Other models that do would let you change that.
Personal Blog
  #30 (permalink)
Old 07-14-2014, 5:09 PM
KevinC's Avatar
Moderator
Which explains why I couldn't find it.
  #31 (permalink)
Old 07-15-2014, 4:30 PM
DaveNF2G's Avatar
(I looked for this thread in the Advanced Tech Topics forum first.)
2 comments about my beta experience:
1) I hope the release firmware allows saving the audio settings per P25 system.
2) Our local multisite LSM system totally evaded the beta. Not one single configuration of audio settings was able to recover any audio! Reverting to 2.05 cured that. Beware!
David T. Stark
NF2G WQMY980 KYR7128
  #32 (permalink)
Old 07-16-2014, 7:45 AM
jasonhouk's Avatar
Auto starts at A9 -A10 seems to stay at 10 , error rate 2-14. While monitoring still getting cross talk group and voice ch hang with pops Marion RR site id 901. Best setting for me was M9 with close to 0 error rate 99# of the time.
  #33 (permalink)
Old 07-16-2014, 9:52 AM
UPMan's Avatar
Exclamation
Focus on Mixed-Mode systems
Some issues appear to remain on Motorola P16 (analog/digital or 3600 bps control channel with all digital channels) systems, but I'd like to see some more reports. We are checking on the Grand Prairie system, but would appreciate additional field reports using the beta firmware.
Specifically, looking for apparent lost reception after some time or incorrect TG traffic appearing after some legitimate TG traffic (i.e. Channel indication doesn't change after one message and new channel traffic comes through).
Or, other effects.
Personal Blog
  #34 (permalink)
Old 07-16-2014, 10:36 AM
northzone's Avatar
I lose signal after a short time on a APCO-25 Common Air Interface Exclusive system ( not a mixed mode) as I have posted several posts back.
This system: http://www.radioreference.com/apps/db/?sid=5317
  #35 (permalink)
Old 07-16-2014, 11:31 AM
UPMan's Avatar
Were you monitoring a single site (all other sites avoided)? If not, how many other sites enabled/being scanned?
Personal Blog
  #36 (permalink)
Old 07-17-2014, 8:32 AM
UPMan's Avatar
I think we've eliminated a lot of the issues on the P16 (mixed digital/analog or digital-only Motorola 3600) systems. Please give this update a shot. Note that this is still a beta release.
http://info.uniden.com/twiki/pub/Hom...1_V2_06_03.zip
Personal Blog
  #37 (permalink)
Old 07-17-2014, 8:08 PM
ve3zo's Avatar
Bell FleetNet - Ontario Provincial Government Zone 1
County: 24 counties
System Type: Motorola Type II SmartZone
System Voice: Analog and APCO-25 Common Air Interface
For the above noted system..Ver 2.06.03 so far cured the problem of the incorrect talkgroup ID ( digital voice on analog talkgroups ) ..however now there is " motorboating " and the digital voice decoding is choppy at best . I adjusted the filter settings and switched from auto to manual ..no difference
Chris
  #38 (permalink)
Old 07-17-2014, 8:22 PM
northzone's Avatar
Single Site (Contra Costa Central). All other sites avoided. Thanks for all the work going into this. It is a great radio.
Downloaded and installed version 2.06.03 . Does the exact same thing. After a few minutes stops receiving completely.
  #39 (permalink)
Old 07-23-2014, 7:46 AM
aliby19's Avatar
Upgraded to 2.06.03 recently and on the Indiana Project Hoosier Safe-T (Motorola) system (https://www.radioreference.com/apps/db/?sid=933), I am experiencing odd behavior.
My HP-1 appears to be losing signal every three seconds or so. I'll go from full signal strength bars to no signal strength bars in the middle of transmissions. This happens both while mobile and while stationary.
Is there any more detailed information I can provide, or any additional troubleshooting steps I can take?
Thanks!
FF/EMT | Hancock Co, IN Public Safety Feed
Radios: Moto 1550XLS VHF, Yaesu VX7R, FT51R, 7800R, FTM400
Scanners: BCD396XT, BCD996XT, HomePatrol-1, Pro-163, Pro-164, Regency MX3000
  #40 (permalink)
V 2.06.03 is unusable on this system.
Bucks County Trunking System, Solebury, Pennsylvania - Scanner Frequencies
During a digital transmission, about once each second, signal indicator drops to zero (no bars), audio stops, signal indicator returns to normal (4 bars), audio returns to normal, cycle repeats.
V 2.06.02 works fine except for some unwanted talk groups appearing after hold times.
Closed Thread
