Old 07-10-2014, 7:28 PM
Default Laird GPS Antenna w/ 536HP
I am trying to price out a new build for a vehicle i will be outfitting with a few uniden 536 hp's. I really want to use the GPS feature of the scanner and i was wondering if anybody knows a way to get a Laird Technologies - GPSUW15M - 3-5V GPS Antenna working with this unit. Any help would be greatly appreciated. Thanks in advance.
Laird Technologies - GPSUW15M - 3-5V GPS Antenna, White
North Jersey BC 996XT | BC 996P2 | 3 X BCT 15X | WHISTLER TRX - 1 | WHISTLER TRX - 2 | BC 346XT | BC 780XLT | 3 X BC 355 | RS Pro 405 | Pro 135 | PRO 2050
Old 07-10-2014, 7:42 PM
The problem I see is you need a rs-232 end to plug into the uniden. This antenna probably has a sma connector on it which plugs into a normal gps unit...kind like the garmin set up. Why not just buy the uniden gps and be done with it. You can paint them with any color.
You be steppin....I be stomping.
Old 07-10-2014, 7:51 PM
That looks like just an antenna. You'd still need the receiver.
I used the Garmin 18x LVC. (LVC has the wires that you have to put a plug on.) You can also get the serial version that has a serial plug and 12v adapter.
Old 07-10-2014, 9:44 PM
I'm using the Uniden GPS device. The antenna portion sits on the dash of my vehicle and does a pretty good job.
Serial GPS Receiver for Scanner and Marine Products
In the past I've used a Garmin eTrex Legend with a 12 volt power wire. It did the job but I didn't like leaving an obvious GPS device on my dash for security reasons.
Any NMEA compatible GPS device works as long as it has that 9 pin RS 232 connection.
(The antenna you posted is but part of a system commonly found on public safety vehicles and buses. It connects to another "box" inside the vehicle. The primary use for that setup is to communicate the vehicle's location to a dispatch center computer so the closest resources are dispatched as needed. This is called "AVL/GPS" or automatic vehicle location based on global positioning system.)
Using a GPS device for location based scanning is a very handy feature which I believe you will like.
