Old 08-08-2014, 11:55 AM
Default Does it HAVE to Blink?
Whenever my 996XT stops on a channel, the display starts blinking. I don't mind changing colors, but is there a way to stop the blinking?
FF
Old 08-08-2014, 12:00 PM
Kingmobileaudio's Avatar
It's an alert programming that you put for that channel.
Old 08-08-2014, 12:05 PM
NHdave's Avatar
Yup, that's user programmable, also not the default setting so you must have changed the setting for it, you can also have it change colors for certain channels.
________________________________
BCD996XT, Pro 106, Pro 2053, BC350A, BC120xlt
Old 08-09-2014, 9:37 AM
Thanks. Using ARC XT I see 4 alert columns. One of these must control the blinking but it is not clear what each one does. Looks like Alert Pattern: On - Slow - Fast controls the blinking. Lacking description in the ARC documentation, Uniden documentation and the Easier to Read documentation. I must be slow.
FF
Old 08-09-2014, 10:47 AM
FF
IIRC, On = On Solid, Slow = Slow Blink, Fast = Fast Blink
