Old 05-28-2015, 3:42 PM
ftl7011's Avatar
Default RH-96 with db9 ?
Has anyone been able to use the rh-96 head with the db9 connector in the back instead of the mini plug in the front with a 996 or BCT15?
Old 05-28-2015, 4:33 PM
The scanner won't recognize the RH (or vice versa).
Old 05-28-2015, 4:40 PM
JoeyC's Avatar
I can't speak for a 996 or a BCT15, but I am controlling my 996XT with a RH96 from the back db9 connector. There are instructions on how to wire the connector somewhere in the forum archives here.
Old 05-29-2015, 11:24 AM
The RH works with the T and XT series. The issue is not the connector - it's that the RH does not recognize the P2 model numbers. For those who may recall, an update was made to the RH-96 so it would work with the XT series even though they are essentially the same as the T series. It's the same with the P2, but I don 't expect Uniden to update the RH firmware to work with the P2 series.
Old 06-24-2015, 9:15 PM
I remember that FW update when the XT models came out!
And I think you speak the truth that there will be no further updates to the RH displays to handle the P2 models.
Old 06-29-2015, 6:40 PM
N9JIG's Avatar
Sheriff
Do you have the pinouts for using your RH-96 on the XT? I think that might be easier than the jack I mounted on the rear of the XT.
Rich Carlson, N9JIG
Facts are facts but my opinions are my own and may not reflect those of whom I work for.
Old 07-06-2015, 1:45 PM
The cable configuration for using the RH96 with the rear DB-9 connector on the BCD996XT is:
3.5mm Tip - DB-9 Pin 3
3.5mm Ring - DB-9 Pin 2
3.5mm Sleeve - DB-9 Pin 5
I built the cable by ordering a cable with a factory-made right-angle 3.5mm plug and adding the DB-9 Female connector.
Old 07-06-2015, 3:51 PM
N9JIG's Avatar
Sheriff
Thanks, it should be easier to use the DB-9 than installing the jack like I did on some of my radios!
Rich Carlson, N9JIG
Old 07-13-2015, 1:17 AM
Scanner / Rh
Tx. = Rx
Rx. = tx
Grounds together
You be steppin....I be stomping.
Old 07-28-2015, 10:37 PM
N9JIG's Avatar
Sheriff
Well, I finally got around to trying the DB-9 connector with my BCT15's, BCT15X;s and 996XT's. It works just fine with each.
I cut off the end of a DB9 cable and toned out the pins. I then cut off a standard 3-wire computer speaker cable (you know the green ended cable that seems to ship with every computer and that you probably have a couple in your junque drawer?). I then connected the wires as shown above and below (from user mbnelson):
Pin 3 to Tip
Pin 2 to Ring
Pin 5 to Sleeve
I did notice a slight latency in response from the scanner, just enough to be noticeable, not enough to be annoying.
I don't have a 996P2 around to try it but might have one soon. I don't think it would work but if you have the parts and an RH-96 around try it and let us know...
Before you ask; no it will not work on a BCD536HP, BCD436HP or BCD325P2. The 325 has no RS232 and the control set on the 436 and 536 are different than that used by the RH-96.
Rich Carlson, N9JIG
Old 07-28-2015, 11:05 PM
Pin 3 to Tip
Pin 2 to Ring
Pin 5 to Sleeve
Good job Rich,
What is the purpose for your build?
Old 07-29-2015, 2:03 AM
It won't work. The RH does not recognize the P2 model number. There was an update in order for it to work with the XT. A similar update would be required for the P2.
Old 07-29-2015, 8:06 AM
N9JIG's Avatar
Sheriff
Originally Posted by scottyhetzel View Post
Good job Rich,
For now it is just a proof of concept. I use RH-96's in my vehicle and the radios there have jacks I wired in on the back panel since the flimsy front serial ports are damaged. The next time I will just use the DB-9 on the back.
I was also talking to a friend yesterday about the idea regarding another project and we were wondering if we could apply it to a 996P2. While we both agree that it probably won't work we thought it would be fun to try. I might send him my cable if he can't build one just for giggles to try it.
Rich Carlson, N9JIG
