This is my 2nd 436HP(Returned the 1st reference key-pad lag) so far and both have had this issue. While I am scanning my Analog Trunked Motorola Type II SmartZone system in St. Lucie County, I have an issue affecting transmissions roughly 60% of the time. The system voice is setup as follows: Analog and APCO-25 Common Air Interface. All the issues are on analog trunked transmissions which is 95% of our traffic on our TRS. The only P25 audio is 3 talkgroups for public transit and 1 air rescue talkgroup.
The problem occurs when short transmissions are sent out such as "10-4" or "54". I have my 396XT side-by-side on the same system programmed the same way using the RR database via FreeScan and Sentinel database download. Consistently, when short transmissions are sent out, the 396XT will not only beat the 436HP opening squelch (Both set to Squelch=2) but the 396XT will also hear the ENTIRE transmission. The 436 will be late on opening squelch and on the Type II system, will turn on the screen(Display set to on=squelch), squelch opens where I can hear the low subadubile hum of the control channel and background, but little/no voice audio will make it through before squelch closes and the background closes squelch. Similarly, on Brevard County's EDACS TRS, normal transmissions have an accompanying trailing beep at the end of transmissions once the unit lets go of the PTT button. With EDACS; squelch will open, the display comes on, displays the unit ID and talkgroup being transmitted on but only voice coming over is a quick background hum and immediate end-transmission beep. The EDACS talkgroups were not ProVoice enabled and were in the clear.
I have already gone through and checked for delay settings and found none selected. I have even held on the same talkgroup between both the 396XT and 436. Consistently, the 436 was slower and did not open squelch fast enough to hear transmissions. I am only 2-3 air miles from our tower so distance is not an issue. Nor is the antenna...Running a BNC(Uniden supplied BNC-SMA Adapter) RS-800 for our 800mHz system. I've also tried this on a dual-loaded Laird 800 on a 3" NMO Mag-mount on my Dodge Ram with similar results.
Dispatch doesn't request the unit to 10-9(Repeat last) so they hear it on their end, just not on mine.
I will attach links below in separate comments videoing the exact issue if it crops up.
Any suggestions or comments would be appreciated.
