  #21 (permalink)
Old 10-07-2015, 4:31 PM
UPMan's Avatar
Uniden Representative
SN (on the label on the outside of the scanner), not ESN.
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
  #22 (permalink)
Old 10-07-2015, 4:59 PM
MStep's Avatar
Deleted - duplicate post.
  #23 (permalink)
Old 10-07-2015, 5:15 PM
UPMan's Avatar
I think you hit the post key twice? Several hours apart, though...
Personal Blog
  #24 (permalink)
Old 10-07-2015, 5:17 PM
It's very encouraging that Uniden has stuck with this and developed a fix for the clock issue. Thank you.
  #25 (permalink)
Old 10-07-2015, 5:45 PM
MStep's Avatar
My bad--- it must have been a computer "burp".
  #26 (permalink)
Old 10-07-2015, 5:47 PM
wise871's Avatar
System worked great, have all three of mine in the system.
Dan
Uniden:BCD436HP,BCD536HP,BCD996p2,HP-1/2e,BCD396XT,BCD996T(XT),BCT15X, BC898T
Radio Shack:PRO-197,PRO-106
Vintage:PRO-25,Sony Air-8
  #27 (permalink)
Old 10-07-2015, 6:01 PM
Default Return packing and back light issue
Will there be proper return packing in the return box to avoid the damage that was caused on some scanners on the last recall?
I have been running my 536 with the back light off to try and prolong the dim issue. Is there a permanent or not?
I also, like some here have posted, do not want to have to send it in again in the future for the back light repair.
  #28 (permalink)
Old 10-07-2015, 10:21 PM
My scanner is installed in a vehicle. The outside casing has been removed to use with the din sleeve. Will I need to put the outside casing back on before shipping?
FT-60R
FT-8800R
BCD-536HP
Motorola Astro Saber III
  #29 (permalink)
Old 10-07-2015, 11:20 PM
dispatcher812's Avatar
I do not have the Battery issue but I do have the dimming back light. Will there be a campaign for just the dimming?
Kevin Fitzsimmons
Uniden BCD536HP BC125AT
  #30 (permalink)
Old 10-08-2015, 9:07 AM
UPMan's Avatar
a) I'm aware of one unit that had claimed packing issues. We adequately protect returned units with proper packing.
b) You don't need to put the outer case back on.
c) This campaign is specifically for the battery issue. If your unit does not have the battery issue, then it is not subject to this campaign. We've made no other announcements regarding any additional campaigns.
Personal Blog
  #31 (permalink)
Old 10-08-2015, 9:42 AM
N4CYA's Avatar
Filed mine. Question, can I write down a letter from the screen dim issue to be fixed as well? So I don't have to send it back in and etc.
  #32 (permalink)
Old 10-08-2015, 9:58 AM
UPMan's Avatar
We will try to screen them all as they are checked out, but to ensure that the dim screen is not missed, I'd recommend taping a note to the scanner indicating that your unit has that issue (same applies to the headphone circuit if yours was affected but has not yet been fixed).
Personal Blog
  #33 (permalink)
Old 10-08-2015, 11:05 AM
se's Avatar
se se is offline
Default ISSUE.
Hello UPMAN.
I noticed this RTC issue in my BCD536hp. I think within the firtst month of buying it ..Are brand new BCD536hp's rolling off the production line as Im typing this with all known hardware and software fixed? Can I do a trade-n with my current BCD536hp and just have Uniden send me out a new one with the fixes?
Sheldon.
  #34 (permalink)
Old 10-08-2015, 11:54 AM
nr2d's Avatar
I'm waiting to replace the BNC connector in my 2nd 536hp. It is intermittent. I disconnet my feedlines from both of my 536HPs during thunderstorms. I also hung Beldon 9913 off the back when I first got both scanners but I have since made a 2' pigtail from the 9913 to the scanner in an effort to not stress the BNC connect too much. I didn't have a problem with my BC796D and BCD996T with hanging the 9913 off of the BNC connector. I found a company that will make the coax assembly fairly cheaply, $22.00 for a 4" assembly. I think the 2" length on the coax puts too much strain on the connections at the connectors. As soon I have that fixed I'll be sending my 1st 536HP which has the battery issue and display dimming issue. So far, now I'm going to jinx myself, my 2nd unit doesn't have the battery issue. I bought it 2 weeks after the initial release when I picked up my 1st 536 HP.
  #35 (permalink)
Old 10-08-2015, 1:03 PM
bravo14's Avatar
UPMan if you see # 5332 you can delete that one. I got a new one at 5402.
Radios Alinco DJ-X10T IC-F43GT BCD396XT PSR-800 BCD536HP BCD436HP HomePatrol-1
YouTube http://www.youtube.com/user/staugfl1991 (videos)
YouTube http://www.youtube.com/user/scannerfreak91 (Scanners)
  #36 (permalink)
Old 10-08-2015, 1:06 PM
I entered my units put in two requests as I use my scanner daily and dont want to be without for a month
I had two submissions and got this back - no details as to what they canceled so should I just enter them again? seeing as I filled them out exactly the same I dont see what the issue is. its called auto complete in web browser so I have nothing "incomplete" this error message is frustrating and useless please advise.
Your reference number is: 5328
We received your entry but it was incomplete and has been cancelled. If this was not intended, please return and start a new entry. Make sure to complete both steps including the entry of your serial number(s).
I submitted Your reference number is 5375.and 5374
K7MHI
  #37 (permalink)
Old 10-08-2015, 1:09 PM
UPMan's Avatar
Bravo: Done.
Sheldon: We are not offering exchanges.
Personal Blog
  #38 (permalink)
Old 10-08-2015, 1:56 PM
se's Avatar
se se is offline
Why not.
Sheldon.
  #39 (permalink)
Old 10-08-2015, 2:10 PM
signal500's Avatar
Enter the serial number located on the back of the scanner, not the ESN that is located in the menu option.
Douglas - K4DPS / WPUT291
My YouTube channel: http://www.youtube.com/user/k4dps
  #40 (permalink)
Old 10-08-2015, 2:19 PM
UPMan's Avatar
The submission I canceled (5328) had no scanners entered and had been abandoned since 1:20 pm yesterday. There are two additional submissions, one for a 436 and one for a 536. Had you intended these to both come in together?
Personal Blog
Tags
recalled, uniden
