BCD436HP
I also purchased the hard leather case from Scanner Master. It's marked in several places with the character string, "caseguys.net."
I haven't seen many pictures of this product so here are a few.
The leather is 2.5 mm thick. That's a little thicker than two dimes on a flat surface, stacked one on top of the other.
If you've handled a holstered side arm, you know the kind of confidence hard leather inspires. It's the same with this case.
I can be quite hard on my things.
Just today I noticed that I casually dropped my scanner into the driver door cup holder (it's a 2007 Sprinter with a very big, very deep cup holder in the door's molding).
I'd have a scratched screen if it weren't for this case.
What I do: I attach the belt clip to the case and slide it onto my belt. If I need to fiddle with the scanner, I invert it (antenna down) and the clip stays on the belt, but with upward pressure, the scanner comes away.
To reattach it, invert the scanner, slide the keyed attachment into the belt clip. It makes a positive locking sound and the scanner safely spins itself upright.
-Jon
