At 1645 CST 6 Nov 2015, the Uniden server is timing out for downloads. Anyone else have this problem?
Thanks,
Dave Crowley
I am trying to install the USB cable driver and receive a message: Unable to connect to Remote Server. This is at 23:25 on FRI 11/06. Damn, can't believe I must be connected just to install a driver. Obviously I am connected to the 'net to be able to post this message. Not good
I am programming a BCD996P2, not x36. I was able to find a copy of the driver cable and install that. It enabled my ability to program the scanner. But when I tried earlier today, the software was still unable to connect to the site for a f/w update.You don't need a USB cable driver for the x36 scanners. Unless you are doing something with the serial mode. To load the scanner with sentinel the scanner should be set to USB mass storage mode (no driver needed). The sd card in the scanner will look like a USB flash drive to the computer.
Yes. Funny thing; I get the same message about not being able to connect to the web site with any of the following:Did you put the scanner in firmware update mode?
Can someone please provide a link to a page that provides SPECIFIC information for these updates. I update my firmware also and would like to know what it changes on my BCD536HP.
Thank you all.
