Old 12-04-2015, 11:07 AM
UPMan's Avatar
Uniden Representative
Default ProVoice Scanning is Here!
Firmware update released moments ago for BCD436HP and BCD536HP. Details are at:
ProVoice < UnidenMan4 < TWiki
A complete list of changes can be found at:
BCD436HPFirmwareUpdate < UnidenMan4 < TWiki
and
BCD536HPFirmwareUpdate < UnidenMan4 < TWiki
ALL: Be sure to also update Sentinel to 1.06.00. Link is in the release notes.
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
Old 12-04-2015, 11:22 AM
tglendye's Avatar
Thanks!
I don't see the Harrisonburg/ Rockingham EDACS ProVoice system in the Sentinel database. It is in RR's. It would not be accurate... LCN has not been determined. Would it be easier adding it to Sentinel and then downloading it to the 436 then editing/ discovering or simply starting from scratch on the system with Sentinel?
Thanks again!
Todd
BCD436HP, PSR-500, PSR-410, Pro-197(x2), BC780xlt and lots of older stuff.
Old 12-04-2015, 11:23 AM
wise871's Avatar
What's the Serial# format for MyUniden? Not enough room to enter it all.
Dan
Uniden:BCD436HP,BCD536HP,BCD996p2,HP-1/2e,BCD396XT,BCD996T(XT),BCT15X, BC898T
Radio Shack:PRO-197,PRO-106
Vintage:PRO-25,Sony Air-8
Old 12-04-2015, 11:25 AM
KevinC's Avatar
Moderator
Leave off the "37" at the beginning.
Someone told me signatures are silly, so I got rid of mine.
Old 12-04-2015, 11:33 AM
wise871's Avatar
Dan
Old 12-04-2015, 11:37 AM
Sanscanman's Avatar
Well I entered my Serial and then ESN per the page and Generated a Key, but it is telling me Key incorrect.
I also made sure i updated Sentinel to 1.06 before applying the firmware update
time to call Tech Support I think
UNIDEN: BCD396T-BC246T-BC296D-BC250D-BC780XLT
RADIOSHACK: Pro-668 - Pro-18 - Pro-107 - Pro-96 - Pro-2067
GRECOM: PSR-500 PSR-800
M/A COM: LPE 200
Old 12-04-2015, 11:48 AM
UPMan's Avatar
If you tell me the last 4 digits of your ESN, I can look into it.
Personal Blog
Old 12-04-2015, 11:51 AM
UPMan's Avatar
The serial number format is 375z38000015 (example)
Personal Blog
Old 12-04-2015, 11:57 AM
Default Do not know what I am Doing wrong
Check Sum passes. in Please go back by clicking your back button and enter a valid 8 digit serial number using integers.
You must enter 8 digits and only 8 digits for the scanner's Serial Number.
Old 12-04-2015, 12:01 PM
UPMan's Avatar
I have no idea where in the process you are when you get that. A little help?
Personal Blog
Old 12-04-2015, 12:03 PM
Trying to be able to purchase Upgrade key but telling me that the ESN is not right.
Old 12-04-2015, 12:04 PM
UPMan's Avatar
I still have no idea where you are in the process when that happens.
Personal Blog
Sanscanman's Avatar
Here you go Paul: 7867
I talked with Kaleb there at tech support and he had me read my serial and the Key to him and told me he would forward it to Development.. I think I have an idea as to the problem after reading the thread. if you are supposed to omit the 37 at the beginning then I messed it up, but no where on the page does it say to omit that when registering your product.
Thank you
M/A COM: LPE 200
Old 12-04-2015, 12:07 PM
UPMan's Avatar
I am development.
I can find no BCD436HP or BCD536HP registered with those last 4 digits.
Personal Blog
Old 12-04-2015, 12:08 PM
UPMan's Avatar
And, you do not omit the 37. You use the S/N (on the label) for the first part. The ESN goes in once the product is registered. See my example posted earlier. In any event, the ESN and Checksum must match, else you'll never get to the purchase link. It is possible to swap 2 digits and still show as a valid checksum, though.
What is your complete ESN?
Personal Blog
Old 12-04-2015, 12:12 PM
Sanscanman's Avatar
I think it will return to 0078 thats the last four of the Serial on the My uniden page because i didnt omite the 37 at the start maybe?
M/A COM: LPE 200
Old 12-04-2015, 12:13 PM
Sanscanman's Avatar
Ok then I guess I messed it up completely I used the serial from settings>firmware
M/A COM: LPE 200
Old 12-04-2015, 12:16 PM
The registration part I just registered my scanner now trying to be able to this You MUST enter a valid ESN to be able to Purchase an Upgrade key.I put in the Sn number that is is on the BCD436hp and it say the check sum is right but my SN is not tried the physical and the Electronic.
Old 12-04-2015, 12:18 PM
UPMan's Avatar
Nope. The S/N doesn't matter, anyway. Only the ESN (but I need the S/N to find your record). Go look in your products at my.uniden.com and tell me what it says your SN is.
Personal Blog
Old 12-04-2015, 12:19 PM
UPMan's Avatar
I'm sorry, Ryan. I think you'll have to call support. I cannot figure out what you are doing or when you are getting an error in the process.
Personal Blog
