I'd like the '536 experts to check me on this one...
I have a fairly new BCD536HP that appears to be missing some talkgroup transmissions on a (very) local P25 system. This occurs even when locked to the system in question. I discovered this by monitoring the same talkgroups with a BCD436 and double-checked that the talkgroups were actually active with Unitrunker.
I also noticed that the signal strength indicator on the display blinks on and off randomly, even though the signal appears to be a full-strength one. I would expect the indicator to go on and off as the radio scans through other systems or conventional channels, but it also does this when it is *locked* on to the desired P25 system, and even the specific site itself.
I have checked for Priority, WX, and Close-Call sampling and all are set to OFF, and I have confirmed that the appropriate service types are selected. For the most part, the radio works well on these particular talkgroups and ALL of them work some of the time, but all of them aren't heard ALL of the time.
Why is this scanner failing to stop on valid talkgroups? Do I need to send this one to Uniden for service? I'd like to hear your thoughts on this oddity.
Thanks for any input.
- John
- John
