Only if your lighter goes on and off with the ignition. That said I believe the 396 uses a sim card, if so you do not want to just switch off the power W/O powering the radio OFF.
The 396 does not have a SIM so forget that. The 396 will not turn on with the application of power. If you turn it off by removing power it can lose settings made while power was on.
