BCD436HP/BCD536HP: How to Access the LCN Finder
So Far Away....
Been trying to use the LCN finder..
OK.
Go to analyze,
edacs/ltr/dmr lcn.....
then Im on the screen where
its asks to input system name...
I enter the system I programed
in..
DMR SEARCH TEST
No Sytems Found Matching my entry....
Where am i going wrong?
I cannot locate the procedure in the 436 manual,,or the easy to read manual either
KevinC
Other
Super Moderator
Home
OK.
Go to analyze,
in..
DMR SEARCH TEST
I usually use the scroll knob and scroll to the first letter of the system, then tap the knob. If you spell out the whole name every little thing has to match.
cellphone
Silent key.
Ahwatukee, AZ (Phoenix)
When it asks for system name, just hit the scroll bar, and it will list every system in the favorite list. One other thing, the favorite list must be active in your scan selection.
So Far Away....
Tried that too..
entered
D for DMR
no systems found.
But ...figured it out..
First I was entering the FL name...Worng...
Then entered the SYSTEM..no luck...
So I enabled the SYSTEM...DoH...Success!
Re read your post and it clicked when I read SYSTEM...
Thank You! Already found two of the LCN's
TxDuster
Dawsonville, GA
The only way I got it to see the system I wanted to look at after entering everything was to:
Manage Favorites>(Favorite list with the system)>Review Edit System>(select system in question)>Edit System Options>ID Search ... turn on..
Take this with a bag of salt as I have that the scanner for a very short time and just tried this last night.
UPMan
In Memoriam
Arlington, TX
The system needs to be scannable (i.e. not avoided, quick key(s) enabled, and either has scannable channels or, if no channels must be in ID Search mode).
ColonelMike
Shepherdsville, KY
I've done the search for LCN 3 different times and about 9 of the frequencies change their number, the other 5 stay the same. This is on a CON with multiple 14 frequencies.
tyytor
Wyoming
BCD436HP: How to Access the LCN Finder
is there a step by step guide to figure out the lcn for a CAP+ system,
i know there is information scatterd throughout the forums,
I do not have ARC536 so I'm programming everything by hand
thanks
UPMan
In Memoriam
Arlington, TX
If you know all the frequencies for the system, program it in as MotoTRBO and just put in random LCNs. Then, run the LCN finder in the scanner. Note that the scanner can only determine the LCN on a frequency if the frequency is in use. A slow CAP+ system might stay on the same frequency for hours at a time, so LCN finder can take a long time to complete.
kb9hgi
IL
so will the LCN finder put them in order for you?
hiegtx
Mentor
Dallas, TX
As it finds the correct LCN for each frequency, it will update that frequency to show the correct LCN value. It's not going to re-sort the site frequencies, but each frequency found will be tagged with the found LCN value. Frequencies that were not 'found', such as ones that were not used by the system (like for low activity as UPMan noted) will have an LCN value of 0 (zero).
Don't forget to save whatever was found before exiting LCN finder.
garys
Instead of using the first letter/scroll knob, I press the "E" key and all of the scannable trunk systems show up. As Upman says, make sure that it's not avoided and is active. If you don't have any TGs turned on, set "ID Search" to on in the system settings for that particular system.
