Old 07-29-2016, 2:08 AM
K8LEA's Avatar
Question Flashing "Hold" signal
Probably the FAQ of the month, sorry. I couldn't find anything....
My BCD396XT works fine, except that I've recently noticed that the "Hold" signal is flashing....
I don't see any performance problems. Which, of course, means that "I didn't notice any" ....
Somehow, this doesn't seem to be normal.
So, is this an "ID10T" error, or is thing supposed to be doing that?
TIA!
("ID10T" is best read as "idiot" .)
Regards,
Stu.
Why write a short note when you can write a novel?
Old 07-29-2016, 2:32 AM
W8RMH's Avatar
It is on System Hold. Just hold down the hold button for a few seconds, the radio will beep twice and show "System Hold Off" and you will be back to normal.
You probably just inadvertently held the hold button down a little too long and put it into that mode.
Page 127 in the manual.
SKYWARN SPOTTER Unication G4 Home Patrol 2 BCD996XT BR330T
Old 07-29-2016, 3:13 AM
K8LEA's Avatar
Talking
W8RMH:
Thanks! It worked....
I likely pushed that button the wrong way.... I wear the thing a lot, too, and that's one of the few buttons that appear to be "live" when the keyboard is locked.
No idea what I did with the manual - I've been using that "Easier To Read" version, and/or some software. IMHO, you can't program this thing from the keyboard.
Again, thanks!
Stu.
Old 07-31-2016, 12:14 AM
K8LEA's Avatar
Question
And another one....
Again using "Easier To Read"....
So, what does this "System Hold" do?
I don't see that in that manual. Still can't find the radio's actual manual.
Regards,
Stu.
Old 07-31-2016, 12:31 AM
wtp wtp is offline
Default easier to read
Mark's Scanners
BCD396XT < UnidenMan4 < TWiki
uniden's manual check page 127 for system hold.
Old 07-31-2016, 12:43 AM
W8RMH's Avatar
http://www.scannermaster.com/v/vspfi..._reference.pdf
It holds on the current system.
Old 07-31-2016, 2:50 AM
K8LEA's Avatar
Smile
wtp:
Thanks! I have Mark's .PDF, but didn't have a link for the Uniden manual.
W8RMH:
Clear as mud .... But thanks. I had the thing in that mode for some time, and never noticed anything amiss (or missing ). However, I normally have ONE (APCO25) trunked system, a couple of simplex channels, and a couple of hi-band repeaters. I expect that "system" here applies only to that APCO25 group, but the unconnected frequencies seem to work in "System Hold".
I am convinced that Uniden handed their software folks a list of useful addresses and/or functions, told 'em to program anything that felt like it should be there.... Couple of bottles of Saki and....
Thanks!
Stu.
Old 07-31-2016, 3:11 AM
If you only scan one system, you would notice no difference. If you scan multiple systems, you would use System Hold to hold on one of those Systems and not scan the others. It's a very useful feature. Of course, it's now eclipsed by the x36 FL/System/Site/Department hold button features.
