I have two 996XT connected to Proscan for remote listening. This system has been working fine for months. Now I no longer pickup control channel of the P25 system I am monitoring. I did the tune to WX check to see if it was a P25 system issue but no luck tuning in the WX channel.
Now My handheld scanner 396 and 436 are programmed using the same database (RR) file and they work fine.
Before anyone asks all firmwares are up to date, squelch is open, etc. I if I tune to a conventional frequencie I can hear static, so the speaker works. The scanner is mounted on a shelf so there is no risk of vibration or movement to the antenna or connectors.
Do scanners just "go bad" out of random? What would cause the scanner to stop receiving any transmission?
I spent hours searching the RR forums looking for a solution before I posted this. There are about a dozen similar posts to mine but no real solution.
Any help would be great,
Thanks!
Thanks!
