  #41 (permalink)
Old 01-11-2017, 3:06 PM
UPMan's Avatar
Uniden Representative
Maybe a pic just before pressing "E".
Uniden Product Ninja
Professional Scanner Developer
Personal Blog
  #42 (permalink)
Old 01-11-2017, 4:52 PM
W4UVV's Avatar
Smile Success at last!!
Finally success at last! I do not know exactly what I did to possibly impact a successful key code entries session. This time I powered on the 536 and selected the menu DMR upgrade key code entry window. Very slowly and carefully sight checked each scrolled entry to the key entry's completion. I pressed "E" and instead of the "Input Processing Error" message, "Processing Please Wait" displayed and subsequently a message similar to "Update Properly Installed". Obviously, I did something wrong but I am not sure exactly what it was.
Thanks again to everyone who took time trying to help me. I was so excited to get a good DMR update processed I haven't thought yet about checking out the area DMR activity with the 534. Since in my area the two major two way radio installers are Motorola affiliated, 95% of central Virginia SDR users are MOTOTRBO.
John
Publisher of the W4UVV VA Frequency Directory
>70,000 | All MOTOTRBO/NXDN Records Color Coded
996XTs/536+MOTOTRBO/Homemade MOTOTRBO/NXDN
SystemInquiries: w4uvv@amsat.org
  #43 (permalink)
Old 01-11-2017, 4:56 PM
W4UVV's Avatar
Smile Finally Success!
I finally did it right and resulted in a successful DMR upgrade. Thanks much for your help and time.
John
  #44 (permalink)
Old 01-11-2017, 4:58 PM
hiegtx's Avatar
Mentor
John
Start here to see what is in use in or near your area: Digital Frequency Search
There is also an import option to bring the data intro Sentinel.
Steve
  #45 (permalink)
Old 01-11-2017, 5:03 PM
W4UVV's Avatar
Smile Key code finally successfully installed
Originally Posted by hiegtx View Post
If you have not already done so, I would suggest going back to the MyUniden page, and verifying that what is shown on the page for your scanner (serial number, ESN, as well as check sum) matches exactly what is on the scanner. If all that matches up, and you have updated to the latest firmware (I believe you said you had, right?), then I'm at loss for other suggestions, assuming that you have verified the correct key (no typos).
Code finally successfully installed. Tnx.
John
  #46 (permalink)
Old 01-11-2017, 5:05 PM
buddrousa's Avatar
Congrats John enjoy and remember if it is not clear adjust the settings
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP BCD536HPx2 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 Tk280 TK2180 MD380x4 NX5300 NX5200 Buddy
  #47 (permalink)
Old 01-11-2017, 5:21 PM
W4UVV's Avatar
Smile DMR databases
Thanks, I am familiar with that database and the import options. I use ARC536PRO for programing my 536. I imported my 996XT files, edited them as FLs and wrote them to my 536. I also have maintained a VA frequency database since 1985 for the common emission modes analog/P25 P1/P2, plus DMR and NXDN.
I am in the process doing a partial master file reconciliation and have been able to flag about 14,000 expired licenses so far which I removed from the master file and saved as a separate "Expired" file. We still have some radio users who continue operating on expired licenses. It is a "snapshot" moment in time but it permits me to remove a big chunk of "clutter" from the master file.
I do FCC updates for Virginia weekly. The majority of DMR licenses in Virginia typically are analog and MOTOTRBO emissions. MOTORTRBO only licenses typically are noticeably smaller in number.
Thanks again.
John
  #48 (permalink)
Old 01-11-2017, 5:23 PM
W4UVV's Avatar
Smile
Tnx. Wish me luck....good luck that is. I've had a full dose of bad luck sourced appropriately to me.
John
