Old 08-12-2017, 11:29 AM
Default Correct Time in Recordings
Is there a way that the time stamp in recordings reflect the ACTUAL time that the call was recorded? This would be extremely useful to pin down exactly when the call came in. Displaying the current time while listening to the recordings is totally useless. Hopefully this mod would not be too hard to do and will show up in a future firmware update.
In a related topic, when there has been 100 recordings received, the 436 creates 1 file. Is the filename consisting of the date and time the time that the LAST recording was received, or the FIRST file? Just wondering. Thanks.
Bill (KH6SZ)
BCD436HP, TRX-1, Pro-668, Pro-528, Pro-51, Pro-38. 4 RTL-SDR USB Dongles.
HTX-202, MD-380, 3 Baufeng UV-5R
Old 08-12-2017, 11:34 AM
marksmith's Avatar
Your post is confusing. Mine show the actual date/time of the recording.
536/436/ws1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
Old 08-12-2017, 11:44 AM
My 436 does not. I just did a test that was recording all night and there was 3 files that was recorded. The filenames were all different (of course), but when you go and listen to the 100 calls for each file, the time and date in the upper right hand corner ALWAYS shows the current time, not the time and date they were individually recorded.
When you say that yours show the actual date/time of the recording, is that the 536 or the 436, or both?
Bill (KH6SZ)
Old 08-12-2017, 12:17 PM
troymail's Avatar
The time displayed on the radio during recording replay is always the current time vs. the time of the recording. I agree - could be improved but they've ignored that kind of request for years now.
The times on the folders and recordings are the time they were created (i.e. begin vs. end time). If I recall correctly, the recording header data contains the end time.
Unication G4
TRX-2,TRX-1,WS1098,1088x2,1095,1080, PSR800x2,500,PRO96
Old 08-12-2017, 12:27 PM
marksmith's Avatar
I now understand the issue.
On both 436 and 536 it does show current time. I never listen to the replays on the radio in the case of these two radios. The actual time of recording is captured in the files, and when I listen to them using MEDIA MONKEY, all of the data for the recorded info shows. I had assumed it was also on the radio.
Just realizing now that it doesn't on the radio.
Old 08-12-2017, 12:47 PM
jonwienke's Avatar
The audio file is timestamped with the scanner's date/time when it received the transmission. The scanner date and time display always shows current time. But if you use third-party programs to hear the recordings, they will show the timestamp rather than current time.
Old 08-12-2017, 3:29 PM
It is just hugely disappointing that Uniden have decided to now go with a file format that means that most of the useful metadata associated with a recording (CTCSS/DCS/DCC/GID etc) cannot be read by any of these 3rd party tools. Replays on the scanner mean you can't see the timestamp. Replays using a PC mean you can't see any useful metadata: it's a mess.
Old 08-12-2017, 4:18 PM
Which are you missing (PC)? I've found tags for everything I use, but might be missing something.
Anyone have a list of all known tags?
BCD536,Hp2(e),HP-1(e)x2, BC780, BCD996t ,BCD996P2, BCD325P2, Pro 2005, 2006(x2), Pro34,VR500,AT803,R5000and other RF capture devices
Old 08-12-2017, 9:00 PM
I believe if one connects their scanner (in Mass Storage) and computer, then looks for the recordings, the name of the recording is the date and time the recording began. Same is true if the recordings are transferred from the scanner to a folder on the computer.
The purpose of the Recordings is to save a transmission to listen later. Logging of data associated with the transmission, such as CTCSS, frequency, signal strength, etc. is a whole 'nother thing. There is software (ARC 536 Pro, ProScan) that will do data logging.
Old 08-12-2017, 9:20 PM
Jay911's Avatar
What is it you don't see?
In the image above, Title is the channel name, Artist is the favorites list name, Conductor is the radio ID (or alias if you have assigned one), Genre is the department name.
If the recording is of a TG discovered during TGID Search, the Title is blank, and Comment is the TGID. [Comment is only "always" the TGID on HP1 in my experience, not the BCDx36HPs.]
And if you need it, color code/CTCSS/DCS/NAC is available in ISRC, as shown below. (ISRC is not displayable in the main screen of the media managing program I use.)
Old 08-13-2017, 3:16 AM
Where's the timestamp of each recording?
/Ubbe
TRX-2 BCD536 HP1 BCT15 BC246 BC346 BR330 UBC3500 Pro2006 Pro2042 Optocom OS545 PCR1000 ICR2500 IC75 DX394 AR8200 IC-R2 IC-R10 UBC780 MD380 CS750 Pro96 Perseus ADCR25 Scout40 DigitalScout
Old 08-13-2017, 3:47 AM
marksmith's Avatar
He didn't select the field for his screen, but it is there to select.
Old 08-13-2017, 3:49 AM
Jay911's Avatar
I hid the filename/path to make the screenshot small enough to post, but it's in that.
Old 08-13-2017, 1:19 PM
Jay911's Avatar
Is there something still missing?
Old 08-13-2017, 2:57 PM
Grafetul if you can advise what tool/tools you are using to see the DCC/CTCSS/DCS info.
AFAIK you can only see any info when you have scanned a channel. I still haven't see anything that can be used to view a recording of a - or example - custom search.
Old 08-13-2017, 5:13 PM
Jay911's Avatar
That's MediaMonkey. The second screenshot is just the "Properties" page on a specific item - just hit Shift+Enter when a recording is highlighted, then move to the second tab to the "Details" page.
I haven't done any custom searches lately but I do know that when a Close Call hit comes in, the information is not included in the usual metadata - you see the info for whatever channel you were in before the CC hit went active. Similarly, the "new" data that comes up for a conventional DMR channel when you leave the name field "blank" does not come up in MediaMonkey, but does show up if you play the recording back on the scanner. Not sure where exactly it is stored in the metadata, but it's not anything that's human-readable (I have tried browsing the headers of the various files in Notepad++ and only seen the obvious data already described).
