OK! Thanks all for the information! The puck is blinking so that takes care of the "is it receiving" question. The baud rate is set to 4800 in the scanner. The part I don't under stand is why the GPS page is "grayed out".
I will take another look at the connections in the morning and see what I find, I thought the DB9 connectors had pulled apart so I cable tied them together (thought that might have been the problem)
Will report what I find!
I use an HP2 on gps in both my vehicles. If all your connections are good, the radio will automatically give you the green GPS indicator top of screen (if it loses gps once connected, it shows orange, and grey if no connection)
I don't even think about it any more. I think the first time it's connected and gets signals it gives a popup saying it has gps and do you want to use it.
Use just favorites lists when around home, but shift to gps and database when I get outside local area. I just plug in the gps, and within a few seconds it finds it.
I have heard of people putting the connector into the radio backwards. I always look to make sure, but I understand it's possible to get it in there backwards.
Your issue is cables or connector.
536/436/ws1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
