boatanchors
I have a BCD996xt that I have been using for some time, I noticed if I go into the menu and scroll down to (Search For) and then scroll to ( Custom Search) just to make the description easy to follow, I programmed my low limit to 162.400 & High Limit 162.600 in and then clicked Custom Search and it just keeps searching and never stop's, I click the hold button and I can scroll thru the weather channels in the limit search and I pick up about 5 different weather stations that are very strong a few full scale on the S-meter., My Antenna is 40 foot in the air with new LMR-400, I repeated the search in the 850mhz range with a Low & High Limit and still the same results, I made sure my squelch level was set correctly and also the mode was set correctly, like FM for the weather and NfM for the 850mhz.. I made a video and posted to my youtube if you could take a look you can see the problem I am having, and Help would be greatly appreciate, I spoke with the techs at Uniden and they haven't a clue nor does there Engineer's..Any Help would be greatly appreciate, I might ad that everything I program in to memory with all the TGID all works great as it should... here is the You tube link
https://www.youtube.com/watch?v=J2lRRf27Bhg
