Old 04-16-2018, 3:17 PM
Metrofire31's Avatar
Angry What Have I Done?
I'm much more accustomed to operating my BCD325P2 but also own a BCD436HP. I haven't turned on the 436 in quite some time but when I tried today, it seems to come on, then powers back off. Is there a way to restore the factory defaults? It doesn't stay on long enough for me to even set the COMPORT on my computer software. I have brand new batteries in the scanner so power wouldn't seem to be the problem. I could use some help!!!!!!
Metrofire31
Franklin, NC
WQIT636
Metrofire31
Franklin, NC
WQIT636 (GMRS)
996P2/996XT/780/796/296D/396T/396XT/436/XTS2500/XTS5000/NX300/CS701
Old 04-16-2018, 3:34 PM
mule1075's Avatar
Metrofire31
Franklin, NC
WQIT636
Sounds like the SD card needs formatting done.
Uniden SDS100/780XLT Motorola HT1000/GM360 Whistler TRX-1
Old 04-16-2018, 3:45 PM
a29zuk's Avatar
Also, double check the new batteries. I've had a dud battery in a new package of batteries before. Or try it with the power cable plugged in.
Jim
Old 04-16-2018, 4:45 PM
Default BCD436HD
So, how would I do that?
Metrofire31
Franklin, NC
WQIT636 (GMRS)
Old 04-16-2018, 4:46 PM
Default BCD436HD
Jim
I used new, good batteries and also powered it via the USB cable.
Metrofire31
Franklin, NC
WQIT636 (GMRS)
Old 04-16-2018, 4:48 PM
mule1075's Avatar
Since you can't get the scanner to stay on you are going to have to use a card reader. Most pcs and laptops have them but you will need a adapter.
Old 04-16-2018, 4:56 PM
jonwienke's Avatar
I would buy a new micro SD card, since the one you have now is probably failing. Get one of the "high endurance" cards because they last much longer in devices that constantly write to the card. A new card will also probably come with the SD card adapter you need if you don't already have one.
Old 04-16-2018, 9:13 PM
Default BCD436HD
I have a card reader and can take a look at the current card. But, assuming the card is the problem, and I buy a new card, what would the next step be? Would a new card likely allow the scanner to stay powered up? And, could I then do a total reset of the scanner, reloading the factory default systems?
Metrofire31
Franklin, NC
WQIT636
Metrofire31
Franklin, NC
WQIT636 (GMRS)
Old 04-16-2018, 9:17 PM
Metrofire31
Franklin, NC
WQIT636
Do a search on this forum for SD card replacement and/or Clear User Data.
The steps for dealing with a new card have been posted.
Old 04-17-2018, 3:31 PM
marksmith's Avatar
Metrofire31
Franklin, NC
WQIT636
There are no factory default systems on the 436.
You need to format a new card with a card reader/adapter, then take the clear user data option in Sentinel, which prepares the card further. Then select what systems via favorites lists, or update the full database and copy this data to the card.
You then should be able to install card in the radio and start.
536/436/ws1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
Old 04-18-2018, 8:12 PM
Default BCD436HD
I am very grateful to all of you who have responded. You given me consistent counsel on what to do to move ahead with my 436. These RR Forums are clear evidence that help is just a post away and that it's true that it takes a village.....
Metrofire31
Franklin, NC
Metrofire31
Franklin, NC
WQIT636 (GMRS)
