Old 05-25-2018, 6:57 PM
mrscanner2008's Avatar
Default UPMAN: logs for LCN finder problems with CAP MAX (TIII)
HI Upman
I have a problem with LCN finder and CAP MAX :
I entered all the frequencies with channel number 0 et SRCH for Color code. When I start LCN Finder, it finds the first LCN and after that its stop receiving signal. I have to save the LCN result and restart LCN finder to receive the signal. But after finding another LCN, no more signal received.
When I start Lcn finder the signal is full but no more signal after finder the first channel.
Only in CAP MAX I have this problem.
WWW.VE2DRO.COM
Icom IC-91AD, Yaesu FT-8900R, Icom IC-7000, KX-3, FTM-400DR (Fusion),Icom IC-R20, BCD396XT,(2)BCD996XT, PSR600, HomePatrol 1, (2)BCT15X, (2)BCD436HP, BCD536HP and TRX-1
Old 05-27-2018, 9:03 AM
Exclamation
Upman
Any news if this error is going to be looked at by your engineering team?
thanks
WWW.VE2DRO.COM
Old 05-27-2018, 9:20 AM
buddrousa's Avatar
The team is in Japan and you posted this on their Saturday it may take a few days but from what I seen all others logs get looked at.
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP SDS100 BCD536HPx4 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 TK2180 MD380x4 NX5300 NX5200
Old 05-28-2018, 9:41 AM
I found Another problems with CAPMAX:
436 and 536 do not give me the same result for the lcn finder.
EX: freq 411.7625 the 436 gave me LCN 9 but the 536 gave me LCN 15.
I repeat the test a dozen time and always the same different result.
both radio with the latest firmware.
WWW.VE2DRO.COM
Old 05-28-2018, 9:44 AM
UPMan's Avatar
Uniden Representative
For the OP, issue is found and fixed in the next version. Don't know if it will affect the last report or not. As noted by others, it is a holiday weekend. And, much of our team was neck deep in ensuring first production of the SDS100 went well (by all accounts, it did). Still, our software engineer took time to dig into this and found the cause. Sometimes I think they are related to the Energizer Bunny...they just keep working, and working...
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
Old 05-28-2018, 9:49 AM
thanks Upman
I will let you know if all problems of CAPMAX will be fix in the next Firmware.
are we on Friday? oh no it's just monday
WWW.VE2DRO.COM
Old 06-02-2018, 9:45 AM
hi UPMAN
the new firmware doesn't solve the problems.
WWW.VE2DRO.COM
Old 06-04-2018, 2:18 PM
UPMan's Avatar
Can you confirm that they system will scan properly w/correct LCN's and that the problem is just LCN finder? Knowing will help us isolate where to look for the issue.
Also, which versions worked (or what is the first version where it stopped working). Or did it never work?
Personal Blog
Old 06-04-2018, 2:46 PM
Hi UPman
the system scan properly with correct (known) LCN (that I found with DSD and many scanner)
Its LCN finder that never work for Capmax.
I can submit logs if you need or raw audio with DSD+ if necessary.
thanks
WWW.VE2DRO.COM
Old 06-05-2018, 10:04 AM
UPMan's Avatar
Originally Posted by mrscanner2008 View Post
HI Upman
According to that log, it looks like LCN Finder was stopped before it ever received a single voice grant message. And, from the middle of the log, it seems to now be scanning a Connect + system. Is this intentional?
If there are no channel grants, the scanner cannot determine the LCNs.
Personal Blog
Old 06-05-2018, 10:17 AM
No It was not intentionnal. I let LCN finder run for 1 hour and it only find 1 LCN and stop receiving signal after.
No CON+ system was scan. Only CAPMAX system was activate.
I will post another log this afternoon when returning home from work.
WWW.VE2DRO.COM
Old 06-05-2018, 10:19 AM
UPMan's Avatar
Ok. For this log, try to quickly MENU and turn off the log when you stop LCN Finder (keeps from having a lot of confusing other data in the log that could muddy up trying to diagnose).
Appreciate your help.
Personal Blog
Old 06-05-2018, 10:31 AM
how long in time do you need for the log ? 15 minutes, 30 minutes, 1 hour ?
I appreciate your help for fixing this problems.
WWW.VE2DRO.COM
Old 06-05-2018, 10:36 AM
jonwienke's Avatar
However long it takes for voice traffic to happen on all voice channels. On a busy system, you only need a few minutes. On some mostly idle systems, it may take a few days. Most systems are somewhere in-between.
If you have a second scanner, program the voice channels as analog conventional so you hear digital noise when the voice channel is active. Then you can confirm if the channel is active by hearing digital noise.
Gone camping.
Old 06-05-2018, 10:37 AM
UPMan's Avatar
If you can confirm that the system has had traffic (2nd scanner scanning conventionally)? Then just long enough for a few misses.
Personal Blog
Old 06-05-2018, 10:40 AM
jonwienke's Avatar
I typed faster this time
Gone camping.
Old 06-05-2018, 5:39 PM
Hi Upman
I made the debug logs for the CAPMAX system.
the system has 5 sites and each site has 3 or 4 frequencies.
the system use RAS.
PD (TG 101) are encrypt.
FD (TG114) and TP are in clear.
I made log for every sites.
on 1 site LCN finder found nothing despite there were communications.
I follow comms with DSD+2.98 and with another scanner with frequencies
in conventional.
Another bugs I forgot to mention: the result of LCN FINDER is not the same
on the 436 et 536 despite they're both with FW 1.22
EX: 413.3125 LCN 11 on 436 and LCN 15 on 536
I rerun the LCN finder many times and never get the same result :
EX:
411.6625 LCN 9 (on test 1) and LCN 13 (on the second test) and LCN 6
(on the third test) on the same scanner (436 or 536).
here is the link for the logs
https://www.dropbox.com/sh/1frwxl6xa...zdyf-k3Ka?dl=0
if you have problems with the link or If you need more logs just let me know.
thanks
WWW.VE2DRO.COM
Old 06-20-2018, 7:13 AM
Angry
Hi Upman
after testing the new firmware for over a week on the CAPMAX system, the result is disappointing: I only receive 30% of communications compared to DSD +.
I have all the LCN (found with DSD because LCN FINDER didn't give the same result twice)
but my 436 et 536 receive few comms.
I know the system use RAS, but with another system, CAP + with RAS, I receive 100% of communications.
thanks
WWW.VE2DRO.COM
Old 06-29-2018, 2:41 PM
Upman
Nothing new with firmware update for CAP MAX (TIII) ???
WWW.VE2DRO.COM
Old 07-02-2018, 2:28 PM
UPMan's Avatar
Hi Upman
the system use RAS.
in conventional.
EX:
thanks
According to that LCN Finder logs, There are logs for 4 sites (Site ID: 1, 3, 4, 5).
Site 1:
It never detects RAS.
Is the signal quality enough?
Site 3:
There are 3 LCNs (LCN: 9, 10, 15).
Site 4:
There is 1 LCN (LCN: 13).
Site 5:
There is 1 LCN (LCN: 11).
Are these LCNs of each site that DSD shows the same as or close to the above?
I'm not sure whether DSD uses LCN or LSN for Tier 3 systems.
Personal Blog
