  #21 (permalink)
Old 06-12-2018, 11:33 AM
petrol88's Avatar
Originally Posted by kikito View Post
(Trying to stay neutral here without taking sides)...
You could also take what UPMan said as neither is necessary because they know about it and they’re working on it?
Either way maybe you could submit a ticket to Uniden Support or something I’m guessing...
Agreed. It is quite clear that he has read this thread and is aware of the report. I don't believe he is under any obligation to make any comment at all...
  #22 (permalink)
Old 06-13-2018, 11:55 AM
UPMan's Avatar
Uniden Representative
Questions for the OP from engineering:
1. Confirm that BCD436HP is not doing the same thing (I think that is correct, but please confirm). If possible, a side-by-side video of both scanning from the same simple FL with only that system would help.
2. What is the RSSI when this is happening (detail mode RSSI is a default field).
3. What is the NOISE value when this is happening (modify detail mode to show NOISE in a field).
4. Is it happening only on analog, only on digital (provoice), or both?
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
  #23 (permalink)
Old 06-13-2018, 2:14 PM
Bolt21's Avatar
Disclaimer: I loaded the beta firmware you posted yesterday to see if it helped with EDACS (didn't think it would - it didn't, figured I didn't have anything to lose), and this data reflects that version.
1. I monitor the Hillsborough EDACS system as I travel for work, didn't have both models with me, and I do not get decent reception at home to provide video, but can assure you that the BCD436HP is NOT doing the same thing. Fyi, this also happens with the EDACS systems in Pasco, Brevard and Indian River counties.
2. RSSI is -50/-45dBm (observed within Hillsborough County)
3. NOISE fluctuates between 150-200 (during transmissions, observed within Hillsborough County)
4. Not 100% sure, but I *believe* it happens on both analog and PV. Most definitely with analog.
Lowly Technician-Class Operator
"If they pull guns at us, make no mistake about it, we will shoot them. A lot." - Polk County Sheriff Grady Judd
  #24 (permalink)
Old 06-13-2018, 3:57 PM
wise871's Avatar
Default SDS100: Is anyone else....
No problem here in the Florida Panhandle. Picking up SLERS in the next County over. Haven’t missed any transmissions and my RSSI is around -90 to -100. From work I get -30 to -40.
Dan
Uniden:SDS100,BCD536HP,BCD996p2,HP-1/2e,BCD396XT,BCD996T(XT),BCT15X, BC898T
Radio Shack:PRO-197,PRO-106
Vintage:PRO-25,Sony Air-8
  #25 (permalink)
Old 06-14-2018, 1:19 PM
Bolt21's Avatar
After today, I'm seriously thinking that my unit might be defective. Today I traveled through Hernando County, which has a Motorola analog system. The SDS100 was exhibiting the same difficulty it had with the EDACS systems - clipping and missing transmissions. At this point, all this thing is good for is systems that suffer from LSM. My 436HP outperforms it in every other category, including decades old trunking technology. I should however, add that it does seem to perform as well as the 436HP on DMR systems.
I would expect performance like this if I was the next county over and trying to listen with a stock rubber duck. A brand new scanner like this shouldn't be having problems within the county with an 800mhz antenna and good signal.
  #26 (permalink)
Old 06-14-2018, 2:20 PM
jonwienke's Avatar
That's a pretty good indicator that raw RF performance is similar, and the firmware is in need of optimizing.
Gone camping.
  #27 (permalink)
Old 06-14-2018, 6:30 PM
Monitoring the City of Hartford CT EDACS system.
1. using a 396XT, no 436
2. RSSI: -83 to -100 (high 80's to 90's)
3. Noise: 197-403 but fluctuates even during transmissions up to 5 digits.
4. Analog
  #28 (permalink)
Old 06-16-2018, 12:27 PM
wise871's Avatar
I stand corrected on my original post. Decided to put my 536 up against the SDS100 using my Multicopler which is connected to a DJ130. While monitoring SLERS (Provoice) my 536 (2 bars) is blowing away my SDS100 (3 bars) which has the beta firmware. When I'm in town close the tower in the --40-50 range it was working fine from what I could tell. Currently my battery is down to 3.75. Seems like Provoice/EDACS are degraded on the SDS100.
Dan
  #29 (permalink)
Old 06-16-2018, 12:48 PM
Yeah, the 400/800MHz DMR/NXDN performance in my area so far is solid and many times is BETTER than my 436. As I type this, the SDS has already picked up 3 transmissions the 436 missed. We’ll see as time goes by...
JustMeAndMyRadios
  #30 (permalink)
Old 06-24-2018, 5:36 AM
Checking from Oahu, HI. EDACS Provoice system here...
my 436 is picking up many transmissions while my SDS100 is missing them. RSSI on the SDS100 is showing -97 up to -110. however the 436 with the stock antenna next to it picks up transmissions just fine.
hoping we see a firmware fix soon. Bought the SDS100 cause of the advertising that it has better reception and does better with Simulcast.
  #31 (permalink)
Old 06-25-2018, 1:03 AM
WoodburyMan's Avatar
Originally Posted by jfr454 View Post
Yes,
while scanning the City of Hartford, CT system which is an 800mhz analog EDACS system the SDS100 is deaf to several transmissions while my 396XT is picking them up. Running both radios side by side same antenna, RS800 with Uniden BNC adapters.
I was beginning to wonder the same thing...
Confirmed. Stuck in I-84/I-91 traffic (Dead stop) for an hour 100 yards from a van on fire. Had HP II and SDS with me. I had State Troop H sites and Hartford selected. HP II got a lot of transmissions SDS100 did not, or clipped them.
Not up in Hartford often so can't verify, but can test with some local 800mhz State L / A repeaters between HP II and SDS100.
  #32 (permalink)
Old 06-25-2018, 6:25 AM
jonwienke's Avatar
There is a beta firmware out specifically to address EDACS reception issues:
https://forums.radioreference.com/un...open-beta.html
Gone camping.
  #33 (permalink)
Old 06-25-2018, 11:32 AM
I am getting the exact opposite here with NXDN. DMR is closer in performance, but 436HP seems bit better. My SDS misses all kinds of LA Metro NXDN that my 436 picks up. I don't understand the reason for different results between kikito and myself. Only time will tell. Awaiting FW updates.
Steve AA6IO - ARRL and W5YI VE
GMRS WQWE213
  #34 (permalink)
Old 06-25-2018, 11:39 AM
jonwienke's Avatar
If you're not doing the comparison with both scanners connected to the same antenna, then the results are going to be inconsistent.
Gone camping.
  #35 (permalink)
Old 06-25-2018, 11:59 AM
Are you talking about LA MTA?
Originally Posted by sshermanmd View Post
I am getting the exact opposite here with NXDN. DMR is closer in performance, but 436HP seems bit better. My SDS misses all kinds of LA Metro NXDN that my 436 picks up. .
  #36 (permalink)
Old 06-25-2018, 3:55 PM
Badboy536's Avatar
After i put the Beta firmware on it fuxed MTA Metro
  #37 (permalink)
Old 06-25-2018, 3:58 PM
Hit_Factor's Avatar
Originally Posted by Badboy536 View Post
it fuxed MTA Metro
Is that good or bad?
73, K8HIT
Icom: IC-7300 ID-5100A ID-51A Plus 2 IC-R30 Hytera PD782G Uniden SDS100 DVMega SDRplay RSPduo
  #38 (permalink)
Old 06-25-2018, 4:09 PM
mciupa's Avatar
Forums Moderator
He used a poorly disguised euphemism for a vulgar word, so I would say, bad.
  #39 (permalink)
Old 06-25-2018, 4:12 PM
Badboy536's Avatar
SORRY it "fixed the problem with Metro MTA" so much better with the beta firmware.
  #40 (permalink)
Old 06-25-2018, 4:15 PM
Badboy536's Avatar
I was having a lot of problems with the first firmware from Sentinel. Missed a lot of com's. But after the latest beta firmware it fixed the Metro MTA and even improved analog receive.
