Old 06-10-2018, 12:11 PM
Bolt21's Avatar
Question SDS100: Is anyone else....
Is anyone else having degraded EDACS performance compared to their x36HP? My SDS100 is clipping off the beginning of some transmissions and flat out missing others. It's so bad that I'm only getting RIDs about half of the time. I'm running the exact same profile that I use with my 436HP - I haven't enabled Close Call or anything else that would alter performance.
A mixed analog/digital system (Sarasota) that I travel through was also exhibiting the clipping and missing transmissions, but not near as bad as the EDACS system (Hillsborough County, FL).
The SDS100 is doing fairly well with LSM, but that's about all that it's doing well, as far as trunked systems go. I'm wondering if I have a defective unit.
Lowly Technician-Class Operator
"If they pull guns at us, make no mistake about it, we will shoot them. A lot." - Polk County Sheriff Grady Judd
Old 06-10-2018, 12:37 PM
Yes,
while scanning the City of Hartford, CT system which is an 800mhz analog EDACS system the SDS100 is deaf to several transmissions while my 396XT is picking them up. Running both radios side by side same antenna, RS800 with Uniden BNC adapters.
I was beginning to wonder the same thing...
Old 06-10-2018, 12:48 PM
Bolt21's Avatar
Phew, that's a relief. Hate that you're having problems too, but I was beginning to lose my mind. At least it's not just me.
Anyone else?
Old 06-10-2018, 2:34 PM
Same problems here compared to my 436. So far, I’m appreciating how well my 436 performs. Had no idea how great a radio it is.until I got the SDS100. Really like the SDS100’s display and build quality. Speaker and performance thus far, not so much.
Old 06-11-2018, 8:05 AM
Bolt21's Avatar
What is the proper course of action here? Try to contact Paul or call Uniden directly?
Old 06-11-2018, 9:00 AM
UPMan's Avatar
Uniden Representative
Neither.
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
Old 06-11-2018, 9:13 AM
Bolt21's Avatar
Neither because you read my post?
Old 06-11-2018, 3:34 PM
Originally Posted by UPMan View Post
Neither.
what the ...
I can confirm - SDS100 EDACS reception (70 cm band) is DRAMATICALLY WORSE THAN BCD436HP.
Firmware on my sds:
main 1.02.03
sub 1.01.03
Old 06-11-2018, 3:56 PM
Neither.
(Trying to stay neutral here without taking sides)...
You could also take what UPMan said as neither is necessary because they know about it and they’re working on it?
Either way maybe you could submit a ticket to Uniden Support or something I’m guessing...
JustMeAndMyRadios
Old 06-11-2018, 4:13 PM
jonwienke's Avatar
Uniden had numerous beta testers doing exactly that. But a limited number of testers can't find every possible problem.
Gone camping.
Old 06-11-2018, 4:21 PM
I believe you are spot-on. Paul keeps close tabs on reports such of this, and while he may not say much right away, I am sure any concerns we have are on his list and looked into.
Old 06-11-2018, 4:27 PM
I'm having problems with Albany NY's Capital Digitronics EDACS systems for Troy PD also with my SDS100. It's basically deaf while my TRX-1 and BCD325P2 hums right along.
Old 06-11-2018, 7:34 PM
MikeOxlong's Avatar
Forums Manager/Global DB Admin/Commie
Default SDS100: Is anyone else....
Gents, this thread was started so users can compare notes on a possible issue with scanning EDACS systems.
If you want to discuss other issues, find another thread or start one of your own.
Thanks.
Mike.
Old 06-11-2018, 7:35 PM
buddrousa's Avatar
Mine is doing good on my systems
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP SDS100 BCD536HPx4 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 TK2180 MD380x4 NX5300 NX5200
Old 06-11-2018, 9:03 PM
Markscan's Avatar
No problem with the NYCOMCO EDACS in Orange County NY.
BCD396XT
BCD996XT
Uniden HP-1x2
Old 06-11-2018, 9:20 PM
jasonhouk's Avatar
I'd take it as it's a known issue on some systems.
Houk
Sent from my Moto G (4) using Tapatalk
Old 06-11-2018, 9:44 PM
jdeverett's Avatar
Sorry, Tapatalk app! What system in Sarasota FL are you talking about. I will be testing my SDS100 in that area the next several days.
Thank you
Old 06-12-2018, 3:22 AM
Bolt21's Avatar
Sarasota County Trunking System, Sarasota County, Florida - Scanner Frequencies
Old 06-12-2018, 5:41 AM
jdeverett's Avatar
Bolt21, I’ll let you know on both those systems of what I get on my SDS100.
Old 06-12-2018, 9:04 AM
mcscanner's Avatar
Living off the North end of DFW airport at 8.7 miles my 536 will pickup the weak signal (RSSI -110) better than my SDS100. SDS100 does fine when parked at the North observation area.
I'm speculating the recovered signal differs between radio designs and needs a little more tweaking for the SDS100.
This system--> https://www.radioreference.com/apps/db/?sid=25
The road goes on forever and the party never ends...
