Old 06-12-2018, 1:49 PM
mclove's Avatar
Post SDS100 uniden
anyone who has uniden sds-100 in Ontario having a problem with onque my shows no ran but color code3 so it dose not work at all
Old 06-12-2018, 2:14 PM
troymail's Avatar
Color Code on a NXDN??????
Color code is used with DMR
RAN is used with NXDN
Unication G5(UHF)
Old 06-12-2018, 2:17 PM
mclove's Avatar
Default SDS100 uniden
i no i dont understand i cant change it so it dont track the onque
Old 06-12-2018, 2:19 PM
RAN, DCC, NAC, they're all color codes. 3 because it's site 3.
Old 06-12-2018, 2:20 PM
troymail's Avatar
In concept - yes.... are you saying that the SDS-100 shows all of these as a "Color Code"?
Unication G5(UHF)
Old 06-12-2018, 2:25 PM
jonwienke's Avatar
Either the system is dmr rather than nxdn, or there is a dmr system on the same frequency nearby. Are you 100% sure onque is nxdn?
The sds100 knows the difference between color code, ran, and NAC.
Old 06-12-2018, 2:29 PM
mclove's Avatar
yes it showing the color code 3 that wrong it should be showing ran 3 so the scanner cant track it cuz its not sure about the system i cant change it from color code to ran maybe a bug uniden need to look at that why i asked if anyone els in the gta having the same thing happend to them on the onque system whit this scanner
Old 06-12-2018, 2:35 PM
W4ELL's Avatar
It looks like you are scanning that directly from the database... it appears that the scanner is importing it as CC3 instead of RAN 3.
It looks to be correct in the db here at RR:
https://www.radioreference.com/apps/db/?siteId=24273
I wonder if there is some oddity with the import from RR to Uniden?
Scanmikey - W4ELL - WQXR836
Old 06-12-2018, 2:42 PM
mclove's Avatar
yes in the database it shows it ran 3 but when i upload to my scanner the display say color code3 no ran so my scanner wont work with onque there no where to change it ran 3 in the scanner
https://www.radioreference.com/apps/db/?sid=8070
Dave
Old 06-12-2018, 2:45 PM
mclove's Avatar
your are right dave the scanner should no that so this must be a bug then
Old 06-12-2018, 2:51 PM
OnQue is not even showing up in my database.
Old 06-12-2018, 2:52 PM
troymail's Avatar
New database appeared (today?) dated 6/11 that contains NXDN systems.
Unication G5(UHF)
Old 06-12-2018, 2:55 PM
I updated the database 20 minutes ago. Airtime Communications (IDAS) is in the Sentinel database but not OnQue.
Old 06-12-2018, 2:57 PM
troymail's Avatar
Check Ontario->Hamilton->Statewide
I just updated a 2nd laptop and it's there...
Unication G5(UHF)
Old 06-12-2018, 2:58 PM
There it is, thanks.
Old 06-12-2018, 3:07 PM
W4ELL's Avatar
I assume you have updated the database today to get the latest NXDN additions?
You could create a favorites list for this system and import/append it directly from the database. After you have it as a favorite, you can change it to use a RAN instead of the CC. You could also check and be sure that the system is showing as a 'NXDN Trunk' system (and not a flavor of DMR) type in the scanner.
Old 06-12-2018, 3:12 PM
mclove's Avatar
i il try that thank you
Old 06-12-2018, 4:48 PM
mclove's Avatar
it didnt work its still the same not happy
Old 06-12-2018, 5:08 PM
jonwienke's Avatar
The system ID, site ID, and frequency shown are correct for OnQue, and according to OnQue's web site, they are definitely NXDN. So it's either a bug in the scanner, or someone is broadcasting DMR on that frequency with color code 3.
Try programming that frequency conventional / Digital Search and see what happens.
