Closed Thread
Old 07-06-2018, 1:30 PM
UPMan's Avatar
Uniden Representative
Default SDS100 Firmware 1.03.03M/1.01.05S Open Beta
Release Notes:
1. Improved reception on P25 trunked systems.
2. Improved reception for short communications on trunked systems.
3. Improved reception on EDACS trunked systems.
4. Fixed the issue that the scanner does not save channel option changes in Simple Trunk
5. Fixed U_Id in GSI response (remote command) issue
Unzip and put both files in the scanner's firmware directory.
http://info.uniden.com/twiki/pub/Par..._V1_01_05S.zip
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
Old 07-06-2018, 1:34 PM
rbrtklamp2's Avatar
Thanks for the Update UPMan, I'll throw it my radio in a few minutes and compare it with the public release on my other.
Thank you for your continued efforts to improve the performance of the radio.
Thanks again,
Bob
Sent from my SM-N910V using Tapatalk
Stop streaming public safety comms before encryption kills our hobby!
Old 07-06-2018, 1:56 PM
@UPMan would that be the firmware folder? Accessing it via This PC
Old 07-06-2018, 2:07 PM
K9JLR's Avatar
Yes, see the image below. When you select mass storage after plugging in the usb cable from the scanner to the computer, select the "firmware" folder from the USB (E) drive folder. Open the folder, and then copy and paste or otherwise transfer the unzipped, downloaded firmware files above to that folder. Once completed, you can unplug the cable and allow the scanner to update the firmware. Go in when finished and verify, through the menu, that the two versions above are current in the scanner.
Jesse, K9JLR
Old 07-06-2018, 2:08 PM
Thanks for the help!!! Cheers!
Old 07-06-2018, 2:26 PM
Even though it worked good before, I can see an improvement with the new beta firmware on my local system. Monroe County Trunking System, Monroe County, Florida - Scanner Frequencies. Especially with the quick responses during transmissions. Will be able to try it on other systems later this weekend. Thanks for the always continued improvements on both your x36 and SDS100 scanners. Don't understand why some are so impatient.
Old 07-06-2018, 2:33 PM
dseven's Avatar
I believe that the recommendation is to NOT unplug the cable, but to hold the power button to initiate the firmware update. I assume that that's intended to reduce risk of power loss due to battery exhaustion during the flashing process (which could result in a brick?)
Old 07-06-2018, 2:35 PM
hiegtx's Avatar
Mentor
I have no problems simply unplugging the cable, after correctly 'ejecting' the scanner's card on the PC.
Steve
SDS100-436HP (2)-536HP-TRX-1-325P2-among others
K9JLR's Avatar
Yes, that's correct - typo in my previous post. the scanner will tell you not to unplug the power source until it's done updating the firmware.
Sent from my Pixel XL using Tapatalk
Jesse, K9JLR
Old 07-06-2018, 3:06 PM
UPMan's Avatar
Open a new thread with that question. Doesn't belong in firmware feedback thread...trying to keep it clear for reports.
Personal Blog
Old 07-06-2018, 3:19 PM
dseven's Avatar
Lots of people get by without wearing a seatbelt too ......
Old 07-06-2018, 3:22 PM
KE4ZNR's Avatar
KE4ZNR@radioreference.com
Folks: a reminder to please help keep this thread on topic.
Do not post in this thread if your question or comment has nothing to do with the listed firmware update.
Any off topic posts will be deleted without warning and infractions may be issued to repeat offenders.
Thanks!
Marshall KE4ZNR
NC/SC Forum Moderator/Database Administrator
Frequently Asked Questions
Forum Rules & Guidelines
@KE4ZNR on Twitter
Old 07-06-2018, 3:37 PM
dseven's Avatar
I'm still seeing continual spasming of the display while monitoring a single P25p1 system with system hold time 0. With system hold time set to 60, it shows periods of stability, interspersed with periods of spasming. No real change here.
I'm also still (not) hearing some missed responses during conversations (compared to a G5 monitoring the same TG) - believe to be due to a missed move to a different voice channel.
Old 07-06-2018, 3:39 PM
This time it updated the Sub CPU.
Thank you UPMan for the SDS-100 Firmware update
Old 07-06-2018, 3:43 PM
is this firmware only for the SDS or for all X36?
Old 07-06-2018, 3:46 PM
KE4ZNR's Avatar
Originally Posted by jodyobrien View Post
is this firm wear only for the SDS or for all X36?
Please read the thread title. Your answer is in the very first word.
Marshall KE4ZNR
@KE4ZNR on Twitter
Old 07-06-2018, 3:50 PM
buddrousa's Avatar
Thanks UPMAN and TEAM
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP SDS100 BCD536HPx3 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 TK2180 MD380x4 NX5300 NX5200
Old 07-06-2018, 3:53 PM
WX4JCW's Avatar
Installed Successfully Testing now, seeing an improvement for sure
Jason WX4JCW EMD/FF/EMT RET
Like Johnny Cash's Song I've been everywhere man, ive been everywhere and monitored it
SDS100,XPR7550,SDR
Old 07-06-2018, 3:57 PM
bravo14's Avatar
I'm testing on a AFB p25 l, Edacs provice, cap+ and con+ system.
So far on Con+ the freq sits there with 3 bars doesn't show the Con+ icon and no sysid or site info shows up either. I have moved the radio around nothing.
Radios Alinco DJ-X10T IC-F43GT BCD396XT PSR-800 BCD536HP BCD436HP BCDSDS100
YouTube http://www.youtube.com/user/staugfl1991 (videos)
YouTube http://www.youtube.com/user/scannerfreak91 (Scanners)
Old 07-06-2018, 4:07 PM
rbrtklamp2's Avatar
Preliminary testing seems to show improved P25 performance on the systems around me hearing many more responses now also the patch bug is now fixed I am hearing the patch on both talk groups. Thank you to UPMan and the Uniden team for this update the scanner seems to be working a lot better. I'll post again after I have had a along time to test the new firmware. But this seems like a big step in the right direction!
Thanks again UPMan
Closed Thread
Tags
sticky
