  #61 (permalink)
Old 08-12-2018, 11:56 AM
jonwienke's Avatar
Unless you're right next to the transmitter antenna, you shouldn't be getting a -35dBm RSSI with the scanner antenna removed. I would suggest documenting the unit's issues on video, so you can send proof of malfunction to the Uniden techs.
  #62 (permalink)
Old 08-12-2018, 2:37 PM
-35 is what mine read when it went deaf the first time.
  #63 (permalink)
Old 08-12-2018, 3:56 PM
wx5uif
Did you ever figure out what was goingon ?
  #64 (permalink)
Old 08-13-2018, 3:49 PM
N0GTG's Avatar
Unhappy Another deaf SDS-100
And now my SDS (SN x227) has gone totally deaf, after exactly 2 months. It began with stopping on conventional channels with what sounded like open squelch, full-scale RSSI bar graph, RSSI -35 dBm, and no actual reception. It never sees a control channel on trunk systems, and no Weather broadcast reception. I did the 1.05.00 and 1.01.05 firmware upgrades, and pulled the battery; no change. It's going back to Uniden for repair.
Curt
MNN-115
www.denver-radio.com
  #65 (permalink)
Old 08-13-2018, 4:22 PM
Sounds almost exactly what happened with mine. I talked to Uniden repair today and they sent me a shipping label to return it. Fingers crossed for its second go-round.
  #66 (permalink)
Old Yesterday, 2:00 PM
sibbley's Avatar
Got mine back from Uniden repair today. Still doesn't receive anything! Hell, now I can't even scroll through the menu. Yes, I cleared user data and uploaded new programming. I'm about done with this scanner.
Too many scanners and radios to use at one time, But I'm trying!
  #67 (permalink)
Old Yesterday, 2:13 PM
troymail's Avatar
That seems like at least the second unit returned but not fixed ... did they provide any info with the repair on what they (think they) did while they had it?
Unication G5(UHF)
  #68 (permalink)
Old Yesterday, 2:15 PM
sibbley's Avatar
They replaced J401. Guess it's a connector between boards. Seriously, do they even check to make sure the scanners work before returning them to customers?
  #69 (permalink)
Old Yesterday, 2:22 PM
sibbley's Avatar
Well, now I get to send it back to repair. At least this time I don't have to pay shipping.
  #70 (permalink)
Old Yesterday, 2:23 PM
troymail's Avatar
Ah - same as the earlier repair - J401.
Sure doesn't sound like it....
Unication G5(UHF)
  #71 (permalink)
Old Yesterday, 2:26 PM
jonwienke's Avatar
Sounds like somebody at Uniden needs to be more diligent with post-repair function checks.
  #72 (permalink)
sibbley's Avatar
Customer service assures me they are checked to be in working order before they are returned. I told Caleb, apparently that is not true.
  #73 (permalink)
Old Yesterday, 10:26 PM
N0GTG's Avatar
And then, after this failure, it started working again (but only for a few hours). Then it failed again. Since this seems to be an intermittent, the J401 problem sounds likely, if it's a connection between two PC boards.
Curt
MNN-115
