Old 08-09-2018, 10:31 AM
Default Sds100 listening to fm radio!?
Is this possible and if so how?
Old 08-09-2018, 10:39 AM
channel>frequency>channel
scanning the pinelands of south jersey bcd436hp pro651 pro652 pro2006 pro2096 bct15 grundig satellit 800
Old 08-09-2018, 10:53 AM
Got it thanks. The only problem now is it keeps cutting in and out frequently worse than having close call set to priority. I'm using the RS800 antenna with full signal and RSSI of -100
Old 08-09-2018, 10:58 AM
Just tried with stock antenna still same results.
Old 08-09-2018, 11:13 AM
seth21w's Avatar
Turn squelch on 0 if listening to fm radio.
Unication G4 Tytera MD390G RTL SDR *Sold SDS100*
Old 08-09-2018, 4:08 PM
eaf1956's Avatar
Darn expensive radio to listen to FM!
Current scanners:BCD 996XT,BCD996P2
BCD536HP (2) and a SDS 100
Ham Gear: Icom 7000, U82, V82, V8, IC 2820, MD2017, Vertex Standard EVX 539, MD 9600, CS 800D, Yaesu FTM100 DR and a YAESU FTM400DR
Old 08-10-2018, 6:41 AM
NWI_Scanner_Guy's Avatar
Truth.
I'll sometimes use my UV-82 to listen to a few local FM stations.
BCT-15X / PRO-2051 / BC-355N
SDS-100 / BC-246T / BC-125AT / PRO-107 / PRO-137
ALINCO DR-605 / UV-5x3 / UV-82HP / UV-82X / UV-3R+ / ANYTONE NSTIG-8R
Old 08-10-2018, 12:00 PM
I have a 436 that I sometimes use to listen to broadcast band. I'm generally listening to the station uplink frequency though, since on my local station the uplink to the antenna site is before they add in the commercials.
Old 08-10-2018, 12:01 PM
Mine just got returned to the seller because the audio on any FM station was atrocious; virtually zero treble, and actively clipped highs, even though the correct bandwidth was selected, with excellent signal levels. The same signals on my 436 sound fantastic, so it's definitely the SDS100 acting up. I'm almost afraid to order another one... if anyone has both the 436 and the SDS100, compare the two on a local FM station, and tell me if they're similar sounding to you. Mine were absolutely not. Thanks!
Sent from my LG-H910 using Tapatalk
Old 08-10-2018, 12:15 PM
mule1075's Avatar
I am confused you bought a SDS100 to listen to fm radio?
Uniden SDS100/780XLT Motorola HT1000/GM360 Whistler TRX-1
Old 08-10-2018, 12:26 PM
I bought it to use at events where I can listen to anything relevant there that I want (I.e. security staff, news media, sports team personnel, broadcast media, etc.). If I'm at a game, having FM broadcast available (like on my 436) lets me check on the game, if there's a controversial call going on. It works on the 436; it utterly failed on my 1st attempt at owning an SDS100.
Old 08-10-2018, 12:44 PM
del1964's Avatar
I just tuned a few FM stations on mine and it sounded great. V12 it's obviously not hi fidelity like my car stereo system but it didn't sound choppy or over driven
http://www.broadcastify.com/listen/feed/3666
Uniden BCD396XT, Home Patrol II, WHISTLER TRX-1, AIRSPY, RTL-SDR, Unitrunker, DSD+, SDS-100, sdrtrunk v0.3.4-beta.2
Old 08-10-2018, 12:50 PM
jonwienke's Avatar
The first couple firmware versions had some issues with broadcast FM, but it's improved a lot.
Old 08-10-2018, 12:52 PM
del1964's Avatar
May be. I'm using the "SDS100 Firmware 1.05.00M/1.01.05S Open Beta"
Old 08-10-2018, 12:55 PM
jonwienke's Avatar
They still need to get the high and low freq cutoffs right for FMB, but it's an improvement over what it was.
Old 08-10-2018, 1:00 PM
del1964's Avatar
FM Radio in action....lol
Old 08-10-2018, 2:15 PM
Do you have a 436 to compare it to? Mine actually sounded overdriven and clipped; I even loaded the beta firmware that Jon mentioned, and heard no difference at all.
Old 08-10-2018, 4:04 PM
jonwienke's Avatar
I have both. The 436 is better at FMB than the SDS100, mainly because the SDS100 firmware still uses the same audio frequency low and high cutoff frequencies for everything, which makes FMB sound like crap.
Old 08-10-2018, 9:42 PM
TailGator911's Avatar
I just tuned to fm broadcast with the SDS and it was ok, then patched thru these Inland Pro Audio 2000 multimedia speakers and - whoa! Sounds good...I am so jazzed with these speakers at this price that I just ordered another set for my computer. I had to turn them down to about 5, real loud was distorted, midrange 5 was nice and clear. I also like the fact that they have a headphone jack out of the master side - something you don't see too often with multimedia speakers. My Bose QC35s sound fantastic thru them, but then those headphones would sound fantastic thru a refrigerator hah
SDS100, TRX-1, BCD536HP, WS-1065, BCT15X, BC895XLT, RS-2006, RS-2035, Misc. Others
ICOM R75, ICOM 746 PRO, YAESU FRG-7, YAESU 2800M, YAESU VX-7R, YAESU FT-2DR
SDR#
