BCD436HP/BCD536HP: ProVoice and DMR Sound Terrible BCD436HP
walt991
I just purchased a used BCD436HP with DMR and ProVoice upgrade. The analog signals all sound good, but ProVoice and DMR modes sound really bad and it’s hard to understand what people are saying. I have ver 1.24.00 firmware. Any ideas what could be wrong or know how I can fix this? Any adjustments?
shadcall
Ormond Beach, FL
It would be helpful to know exactly what you are attempting to monitor. This way we can give you suggestions to address your specific problem. I have a 436 and monitor both local DMR and Provoice channels. Both come in loud and clear. I am using an indoor antenna that extends a couple of feet when full expanded.
tampatracker
Ditto this. Everything works L & C. Your systems would help us.
walt991
The ProVoice system is Flagler County. The DMR system was an amateur repeater on 440.
bgav
Central MA
What's your proximity to the two? Could be marginal reception at which point digital decoding breaks down..
CorwinScansNM
NM
I just purchased a used BCD436HP with DMR and ProVoice upgrade. I have ver 1.24.00 firmware.
Version 1.24.00 firmware??
That I know of & can see, there is no such firmware version 1.24.00 released yet for the BCD#36HP line of scanners. The latest most up to date firmware version would be, 1.23.00 for the BCD#36HP line of Uniden Scanners
BCD436HPFirmwareUpdate < UnidenMan4 < TWiki
hiegtx
Mentor
Dallas, TX
Version 1.23 is the latest "public release" version, that can be applied via Sentinel. As walt noted, V1.24 has been released as an open beta, and must be applied manually.
CorwinScansNM
NM
Hmmm, firmware update version 1.24.00 must currently be out only for Beta Testing but not posted under their firmware version release notes for that reason? I was not aware of any Beta or other future firmware update versions for the BCD#36HP line of Uniden Scanners. I certainly didn't expect that at all from Uniden either due to their newest released SDS100 that they are now mainly focusing on & putting thier firmware update efforts into. It's quite good to know that they are still caring for, fixing & addressing bugs & problems still with their last old line of scanners.
CorwinScansNM
NM
OK, now I understand the Version 1.24.00. Gotcha
