  #21 (permalink)
Old 10-12-2018, 2:53 AM
rbrtklamp2's Avatar
No I know it wasn't directed at just me but I also know Uniden Support maybe watching this thread so I just wanted to make sure I stated I have not made any modifications to the my scanners I have to send my like new 436 in as well for the repair campaign because I never got around to that either.
Sent from my SM-N960U using Tapatalk
Ý
Stop streaming public safety comms before encryption kills our hobby!
  #22 (permalink)
Old 10-12-2018, 9:39 AM
Uniden Representative
I'm not here to judge, just give advice. No, we do not recommend modifying your scanner, it can void your warranty and deny you repairs outside of it, but I'm sure you know that going in. Still, it's a rewarding hobby that allows you to customize your scanner to your liking. I don't condemn it and even respect it... it can just screw you over
  #23 (permalink)
Old 10-12-2018, 9:42 AM
Also, modifications are picked up by repair and they make decisions on if the unit is going to be repaired, I'm not going to spend my day trying to find out who modifies their scanners and match their user accounts with who they are. Or am I
  #24 (permalink)
Old 10-12-2018, 9:46 AM
werinshades's Avatar
How does the q1/q2 transistor become damaged? Is this a "possible" defect during the build out or something else we can all look out for or be careful not to do?
  #25 (permalink)
Old 10-12-2018, 10:20 AM
Honestly, depending on what they are being used for, transistors have a fairly high failure rate compared to other components in any electronic. One of the main functions of them is to amplify current, and any shorts in the system can cause a lot of stress on them. We haven't had a ton of SDS100s go through our repair department, and those are not commonly the reason they have.
It is possible it is a manufacturing defect; anyone who has worked in a factory can tell you mistakes can happen. it's the job of ISO compliance to minimize that, and it's a big part of why we have warranties. A transistor is likely to fail if any of the components in the circuit have a problem, so while they may pop up as a replaced part often, it can be caused by any number of failures. We track all of these failures and if there was any sort of common defect, we remedy them, but it does not seem to be the case here.
Most likely it's not anything you are doing with your unit, you can help ensure the health of your scanner by avoiding dropping it, making sure it has good air flow around it, and as hard as it may be, sometimes it's good to give them a bit of a rest.
  #26 (permalink)
Old 10-12-2018, 10:22 AM
Thank you for the explanation and suggestions.
  #27 (permalink)
Old 10-12-2018, 10:25 AM
UPMan's Avatar
Specifically, Q1 and Q2 are prone to damage by high RF exposure. They are part of the RF Amp/AGC circuit (just past the band filters).
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
  #28 (permalink)
Old 10-12-2018, 10:33 AM
Ah ok...so don't get close to a two way radio transmitting for an extended period of time.
  #29 (permalink)
Old 10-12-2018, 10:38 AM
UPMan's Avatar
True that (for every receiver, but especially wideband receivers like scanners).
Personal Blog
  #30 (permalink)
Old 10-12-2018, 12:54 PM
bob550's Avatar
I'd be curious as to whether more failures were experienced by Hams than by others.
Uniden BCD536HP, BCD996xt, BC890XLT, RS PRO-651, PRO-163, PRO-2006, PRO-93, Icom R5, R71A, Sony ICF-2010; SDRPlay RSP2, RTL-SDR V3
  #31 (permalink)
Old 10-12-2018, 1:05 PM
UPMan's Avatar
No way to know that...
Personal Blog
  #32 (permalink)
Old 10-12-2018, 8:57 PM
radio3353's Avatar
I don't modify my scanners, especially not ones I paid 650 dollars for.
And that are still under warranty.
  #33 (permalink)
Old 10-13-2018, 2:29 AM
rbrtklamp2's Avatar
I am going to call Uniden on Monday and send both of my SDS100s in for warranty repairs and we will see where we go from there I will keep you all posted on how it goes and the outcome and quality of audio after the repairs. Hopefully they can fix the keypad light on them as well as they are quite dim right now. I also have to send in my 436 and 536 for failing displays and RTC issues all sorts of uniden fun coming my way. As I said I will keep the thread updated
Ý
  #34 (permalink)
Old 10-13-2018, 1:57 PM
CQ's Avatar
CQ CQ is offline
Default Typcial Use Case
Distance from TX and RX antennas?
Define high power.
So having a mobile RX antenna connected to the SDS100 mounted anywhere from 2 - 6 ft. and receiving up to 50W from a TX antenna is going to kill the scanner if it's on?
My nuclear button is much bigger than yours
  #35 (permalink)
Old 10-13-2018, 4:09 PM
Can confirm ó I needed Q1 & Q2 to get replaced on my HP-1 by putting 50w into it from 10ft away at VHF.
  #36 (permalink)
Old 10-13-2018, 4:57 PM
Does it have back to back protection diodes across the input?
  #37 (permalink)
Old 10-13-2018, 5:39 PM
TailGator911's Avatar
Horsepuckey. I transmit 50-100 watts PEP VHF (2m) on my Icom 746 Pro quite often (usually everyday) and my SDS100 sits on a desk stand 3-ft away and is not affected in the least. No problems whatsoever.
SDS100, TRX-1, BCD536HP, WS-1065, BCT15X, BC895XLT, PRO-2006, PRO-2035, BC125AT, PRO-2051
ICOM R75, ICOM 746 PRO, YAESU FRG-7, YAESU 2800M, YAESU VX-7R, YAESU FT-2DR, FT-857D
SDR#
  #38 (permalink)
Old 10-13-2018, 5:55 PM
Default Problem with a SDS100
I love that you think your situation applies universally. Your antenna for the Icom probably isnít all that close...itís probably outside past roof level...vertical separation is more effective than horizontal separation. PEP is also different to RMS.
  #39 (permalink)
Old 10-13-2018, 7:51 PM
I love it that you think you know how I have my antennas set up. I also really appreciate the power theory clarification. What would I do without you?
My situation only applies to me, myself. Nothing universal intended there. I transmit on several different radios at my station, none of which affect my SDS100's inner circuitry. At no time did I intend to insinuate that my situation applies universally. How you came up with that defies reason. (?) No explanation needed tho, thanks anyway...
SDR#
  #40 (permalink)
Old 10-13-2018, 10:49 PM
rbrtklamp2's Avatar
Hey guys can we please stay on topic with this thread. I would really like to get this situation for all of is experiencing problems with our radios.
Ý
