  #41 (permalink)
Old Yesterday, 11:40 AM
50W at 10 feet result in 0.3W and 5volt in a 50 ohm system. A couple of antiparallell diods whould have protected the input. The only schematic of Uniden scanner I have are for the BC780 and that have protection diods at the antenna input.
/Ubbe
  #42 (permalink)
Old Yesterday, 4:01 PM
CQ's Avatar
CQ CQ is offline
Originally Posted by TailGator911 View Post
Horsepuckey. I transmit 50-100 watts PEP VHF (2m) on my Icom 746 Pro quite often (usually everyday) and my SDS100 sits on a desk stand 3-ft away and is not affected in the least. No problems whatsoever.
I'm assuming your radios are 3 ft. away from each other (transceiver/scanner) in a fixed station and not from a TX antenna, correct?
I've had radios side/side and stacked for years with no issues. I was referring to TX antenna to SDS100 RX antenna distance as typically mounted in vehicles.
My nuclear button is much bigger than yours
  #43 (permalink)
Old Yesterday, 6:15 PM
TailGator911's Avatar
I should have taken the time to read your post more thoroughly and noted that you were referring to a vehicular scenario. Thanks for pointing that out to me in a polite manner. I apologize for any distraction.
JD
kf4anc
SDS100, TRX-1, BCD536HP, WS-1065, BCT15X, BC895XLT, PRO-2006, PRO-2035, BC125AT, PRO-2051
ICOM R75, ICOM 746 PRO, YAESU FRG-7, YAESU 2800M, YAESU VX-7R, YAESU FT-2DR, FT-857D
TOO MANY!
