  #21 (permalink)
Old 11-08-2018, 5:13 PM
tampatracker's Avatar
All those check negative, that's what I though too at first.
SDS 100, BCD436HP x 2, 396XT, PSR-500, ICOM R-75, WS 1088, HP 2.
  #22 (permalink)
Old 11-08-2018, 5:22 PM
jasonhouk's Avatar
Have you tried IFX? Hold on the channel then press function 7 and see if that helps. Could be an image or adjacent channel overloading the front end.
Houk
Sent from my Moto G (4) using Tapatalk
  #23 (permalink)
Old 11-09-2018, 9:45 AM
Uniden Representative
Originally Posted by tumegpc View Post
Uniden Tech/Customer support,
Is there a chance that you clean up the Radio Scanner Accessories page and add real descriptions that let us know that the Rubber Keypad is for which scanner and if it's in stock without needing to click on the item? And yes I do see the Model: BKEY0149001. 99% of us don't know that it's a Keyboard Rubber for BC60XLT-1.
And what is a "Decoration Piece" BCT15X DECORATION PIECE ?
I've passed your suggestions on. The decoration piece has been renamed, it is actually the faceplate for the scanner.
  #24 (permalink)
Old 11-09-2018, 11:58 AM
Houk
I'll give this a shot, thanks jason.
  #25 (permalink)
Old 11-09-2018, 12:33 PM
Yeah, this is an odd one. My instincts want to go for something with the system in your area or environmental interference, but I would hate to write it off as such. Try what Jason suggests, but It might be useful to call us at 1-800-297-1023 for some more thorough troubleshooting.
  #26 (permalink)
Old 11-09-2018, 1:59 PM
Originally Posted by bearcat View Post
I think I am under warranty. I am going to try to borrow a dongle locally. Also I will reload the FW to both.
What is the right FW for the WIFI? 7.28?
I will proceed from there.
Based on what has been mentioned here. The 536 must see a WIFI signal from a tablet, phone, laptop to activate the AP mode. Is that the why the unit is designed to work?
Also it was mentioned to change the static IP address. Is there a way to change the static IP address? I cannot find that option.
  #27 (permalink)
Old 11-09-2018, 2:01 PM
I couldn't find a way to change it either.
  #28 (permalink)
Old 11-09-2018, 2:15 PM
Thanks for the consolidated thread,
Is there any way, perhaps with a firmware update, to improve the s/n ratio on VHF and UHF narrowband FM on the SDS100. P25 sounds fine.
  #29 (permalink)
Old 11-12-2018, 9:08 AM
I am not sure if this is possible, but it has been passed along prior to this message.
  #30 (permalink)
Old 11-16-2018, 5:39 PM
tglendye's Avatar
Is there a place to purchase a new keypad for the 436? Itís always been unavailable on Uidenís site when Iíve checked.
Todd
BCD436HP, PSR-500, PSR-410, Pro-197(x2), BC780xlt and lots of older stuff.
  #31 (permalink)
Old 11-17-2018, 5:57 AM
Are Uniden planning to offer a more durable button replacement for the BCD536HP?
/Ubbe
Tags
sticky, unidenparts.com
