Old 03-15-2009, 12:31 PM
Default BCT15 Tone out feature
What's the trick to getting the tone out feature to work on this scanner?? I also have a 996t and have the same issue.
I have tried programming them manually and via pc, no luck either way.
Channels and tone numbers are correct...
"He who dies with the most toys wins"
Old 03-15-2009, 1:05 PM
captclint's Avatar
Mentor
On the outside chance you did not know, you can not be scanning. You must have the radio set for FTO only. Fire Tone Out - The RadioReference Wiki From the wiki: "Per UPman, setting the wrong mode will affect the accuracy of the decoding. Try changing the modulation from Auto to one of the other 2 modes, dependent on what the correct default is for the frequency being monitored."
Regards,
Clint Chamberlin
Luzerne County, PA
