  #21 (permalink)
Old 05-23-2009, 9:36 AM
Jay911's Avatar
Guess I'm gonna find out today when I head to Red Deer for the weekend how this version behaves on oddball trunk systems such as those, requiring a weird band plan. Haven't had much chance to listen to anything else since I applied the update, but the very short time I listened, my local 3600 analog/P25 system was working fine.
--j.
@Jay91150 and @RMESFire | http://www.rmesfire.org
  #22 (permalink)
Old 05-24-2009, 1:14 PM
suttles1972's Avatar
After several attempts from both , my desktop and my laptop, I am unsuccessful in updating my XT for 4 days now. I am using VISTA Home Premium with both computers and the results are the same. It seems that communication isn't agreeing with the scanner and the computer. After multiple attempts this morning, I am convince that my problem is an O/S issue. For my computers recognized the scanner when I use the USB connection. But when using VUP version 2.0.0.7, I am useless to the Vista O/S. So my question now is, what are my options to updating my scanner. Belows is a list of all things I did to troubleshoot potential reasons behind the communication error between the scanner and the computers.
1. Uninstalled and reinstalled the VUP software.
2. Uninstalled and reinstalled the USB-1 software.
3. Changed com ports several times.
4. Used other scanners to see if the cable was communicating with the computer.
5. Changed the serial port speed on both, scanner and VUP.
If I missed something, please let me know. Because at this time, I'm all ears on suggestions, for everything I've done is not working.
Thanks in advance.
Lieutenant W. Suttles
Chattanooga Fire-Rescue
"Scanning is a true sport".
  #23 (permalink)
Old 05-24-2009, 1:44 PM
Thanks in advance.
Are you getting an ERROR message or what exactly are you doing step by step.
  #24 (permalink)
Old 05-24-2009, 6:19 PM
I am receiving a comm error.
  #25 (permalink)
Old 05-24-2009, 11:26 PM
mclove's Avatar
Smile update
hey just did the update for my 396xl works good in canada i still wish for radio ids upman pls make it happend bro i no u can
  #26 (permalink)
Old 05-25-2009, 7:20 AM
Thanks in advance.
Hey Suttles. Sorry to hear you are having problems getthing the update to run. My thoughts, although you may have tried them. Do you have a COM port on your machine or are you only able to use the USB connection for this machine? I am running Win7 but used the COM connection to update without issue. If you have a COM port available, it may be easier to troubleshoot. Are you using FreeScan to program/control the scanner? If so, are you successfully able to control the scanner? If so, what port & speed is FreeScan setup for, assuming COM connection. Is the updater the only thing running while you attempt to update? Possibly there is a conflict due to two applications (FreeScan, any other scanner software) trying to talk to the device simultaneously?!?
I don't use the USB cable so this is a shot in the dark. Have you tried multiple USB slots on your machine? Front/Back depending on machine? Possibly some are USB2.0? When you connected the scanner, are you logged on as an Administrator? Were you prompted by UAC?
Hope you get this working
-Jim
  #27 (permalink)
Old 05-25-2009, 3:00 PM
Jim, thanks for your response. I am using all USB connection with both devices. However, the laptop may have a com connection. FreeScan works on both computers. But firmware updates aren't communicating with the same setup as the connections for Freescan. This brings me to my initial thought that I'm experiencing an O/S conflict with the VUP. If I could trouble someone with a 2.0.0.3 version, I believe this may be my solution. But until then, I may try the laptop com connection and see if the solution lies there.
  #28 (permalink)
Old 05-25-2009, 3:21 PM
cpuerror's Avatar
You might want to remove any USB hubs or extension cables because they can mess up BC_VUP. I had the exact same problem with everything working with an adaptor except the update program. Ended up using an older computer with a hardware serial port.
FreeSCAN for Uniden DMA scanners, IRLP*Me for iOS devices
Twitter - @FreeSCAN
  #29 (permalink)
Old 05-25-2009, 3:38 PM
I had the same problem and then remembered, I forgot to take out the batteries and plug in the power cord holding down the L/O and 6 button. After I did that I used comm 4 and it worked. Hope this helps.
  #30 (permalink)
Old 05-26-2009, 6:09 PM
This worked. Removing the batteries was the key to my whole issue. I thank everyone for lending a helping hand.
  #31 (permalink)
Old 05-26-2009, 10:57 PM
Smile
Awesome
  #32 (permalink)
Old 08-24-2009, 11:54 AM
jpalm's Avatar
You guy's are way ahead of me. I can't even register my 346T at the Uniden site. Keep getting a serial number error when I know it's correct. I gave up.
  #33 (permalink)
Old 08-24-2009, 12:26 PM
UPMan's Avatar
Uniden Representative
Did you pick the correct scanner model (BC346XT)?
You don't need to register to get the update.
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
  #34 (permalink)
Old 08-22-2010, 6:45 PM
Default Blank display on my 346xt
Sorry, see new thread.
Wayne
Last edited by Boatboy; 08-22-2010 at 6:50 PM.. Reason: SHOULD HAVE BEEN NEW THREAD
