Old 11-28-2009, 5:08 PM
res1oz9a's Avatar
Exclamation Belkin F5U109 USB to serial adapter
I have a Uniden BCD396T and 1 serial port that a UPS is hooked too...
I have a USB to Serial adapter that I would like to use in WIndows 7 x64 but Belkin does not have hany drivers for x64 anything....
Anyone get this working in vista/windows 7 x64 yet? If not what cable do you use and where do I get one?
Old 11-28-2009, 6:30 PM
UPMan's Avatar
Uniden Representative
Most Belkin cables I've seen use the PL2303 chip set. You can download those drivers directly from Prolific at http://www.prolific.com.tw/support/f...ler_v10626.zip
If your cable does not use that chip set, the above driver won't work.
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
Old 11-28-2009, 7:12 PM
wbigcount's Avatar
My uniden Serial adapter wouldnt work with vista at all. I installed windows 7 64x and it worked right away, didnt have to install drivers or anything it found it on its own. I think it is the PL2303 chip set also
This message is hidden because ------- is on your ignore list. Ahhhh Much better!
Old 11-29-2009, 8:25 AM
res1oz9a's Avatar
Well it is not the PL2303 chipset in it.. (bummer) it has this in it (i took it apart to see which chipset)...
Guess its time to shop for a new converter or disconnect the UPS
Old 11-29-2009, 11:09 AM
UPMan's Avatar
According to Belkin : Support : F5U109/F5U409 USB PDA Adapter - Drivers it will work in Vista 64, but no mention of W7.
Personal Blog
Old 02-13-2011, 10:25 PM
The device does work in windows 7 (32bit & 64 bit drivers, just not with belkin's drivers.
See this site for details: How to use a Belkin F5U409/F5U409-CU USB To PDA Serial Converter in Visa/Windows 7 64bit & Mac OSX 10 ClearChain
Old 07-10-2011, 8:02 PM
Default USB to Serial adapter
The only good USB to Serial adapter I have found is from U.S. Converters. I have been using the PRO version with Windows 7 64-bit for several months now without any problems. Highly recommended.
