  #81 (permalink)
Old 07-12-2005, 5:28 AM
Joseph11's Avatar
Originally Posted by pboy
Thanks for passing along the recommendation. Once you get the soundcard audio routed to the program, it works great!
You're welcome. I found that that program can be precise sometimes with the frequencies of tones.
  #82 (permalink)
Old 07-12-2005, 7:36 AM
whsbuss's Avatar
Originally Posted by Voyager
Originally Posted by whooey
What does delay set to OFF do in FTO mode?
It means it won't let you hear the announcement at all. Set to 5, it waits 5 seconds for an announcement. If it's not received in that time (or at least some carrier activity), it will revert back to standby mode (waiting for a decode).
Joe M.
Set to INFINITE it will continue to stay open until you reset it (FUNC).
  #83 (permalink)
Old 07-12-2005, 7:41 AM
UPMan's Avatar
Uniden Representative
set it to infinite
Only an option after the firmware update...
OFF position could be used also in environments where you don't want the scanner blasting out...Set the alert level fairly low. If you get an alert and are in a position to listen w/o disturbing others, press HOLD to hear the audio at whatever the master volume level is at.
  #84 (permalink)
Old 07-12-2005, 8:38 AM
whsbuss's Avatar
Originally Posted by UPMan
set it to infinite
Thanks for the correction. The software already has this option.
Also, can you clarify the difference between Detect and Monitor modes in the FTO?
  #85 (permalink)
Old 07-12-2005, 8:44 AM
UPMan's Avatar
After the update, the terminology will change to be clearer:
STANDBY: This is "pager" mode.
HOLD: This will tone-out, but you'll hear all comms on the frequency, too (no squelch inhibit). In other words, it HOLDS on the frequency.
I don't offhand remember which was which on the original firmware...and I'm running the new version so I cannot easily check. I think MONITOR = HOLD and DETECT = STANDBY, but might have this swapped.
  #86 (permalink)
Old 07-12-2005, 9:03 AM
1080iAddict's Avatar
The initial firmware settings are "Mode" = silent until tone out and "Detect" = frequency open for monitoring.
Paul,
It looks from your description that the new "STANDBY" mode will monitor the frequency AND tone out? If so, EXCELLENT and thanks! Is there any shot at all that the new firmware will include the ability to selectively lockout FTOs on the same frequency per the earlier posts, i.e., monitor 1 station or multiple stations at option of the user on any given frequency?
I have never seen any project manager of a manufacturer actively participate and listen to user feedback over the internet. Great job and thank you again.
  #87 (permalink)
Old 07-12-2005, 9:40 AM
Originally Posted by 1080iAddict
The initial firmware settings are "Hold" = silent until tone out and "Detect" = frequency open for monitoring.
On the display using the inital firmware I get either Tone Out Mode or Tone Out Detect. I assume that Mode = silent until tone out?
73 Eric
  #88 (permalink)
Old 07-12-2005, 10:02 AM
73 Eric
oops. I meant to say "mode" and will edit. 'Hold' is what you press to cycle between the modes.
  #89 (permalink)
Old 07-12-2005, 2:40 PM
whsbuss's Avatar
As was mentioned earlier, the software programming for FTO will NOT WORK!
You can, however, edit the config file until the new firmware comes out.
Here's my example:
ToneOut,5,Sta.33,00337000,FM,OFF,INF,6,AUTO,04266, ,03467,,
(prior to editing)
ToneOut,5,Sta.33,00337000,FM,OFF,INF,6,AUTO,04266,3000,03467,3000,1
(after editing)
You must insert the tone duration for each tone and the tone gap. I've indicated those parameters in bold.
  #90 (permalink)
Old 07-12-2005, 6:13 PM
whsbuss's Avatar
Question:
How critical is the tone duration setting? I have my local EMS set and I cannot get FTO to alert. They get paged alot so its easy to keep changing the duration and waiting for another call.
I tried 3000ms, 2500ms and 2000ms but still no cigar. I know I have the correct tone freqs. (742.5 and 892.5). Any ideas?
EDIT: does the radio have to be in FTO Mode or will it alert in FTO Detect?
  #91 (permalink)
Old 07-12-2005, 6:48 PM
Timing needs to be within 100 msec. Can you record a tone out and post it?
  #92 (permalink)
Old 07-12-2005, 8:06 PM
Originally Posted by whsbuss
Question:
With all due respect, I should not answer this because both answers are in this thread. But I will in good faith. The unit will NOT tone out on Detect - it most be in Mode - under this firmware. All durations must be pretty precise. If you measure the durations in accordance with the suggestions in this thread, you can get an EXACT measurement and your FTO will work. Or just wait until the firmware upgrade.
good luck.
  #93 (permalink)
Old 07-13-2005, 12:05 AM
wizard of odd
I just got my scanner today and I've been doing some playing.
I took a buisness band radio and plugged it into my computer and started playing tones and adjusting setttings.
Tones need to be about +/- 4hz.
Spacing needs to be around +/- 100ms.
My pager (which is not even on the same freq) would alert when the scanner stood quiet.
  #94 (permalink)
Old 07-13-2005, 2:13 AM
You do have an alert tone programmed, right? What is your delay set to? How fast did the announcement follow the tones? If it was more than 2 seconds, that is the default delay and the scanner went back into standby mode.
+/- 4 Hz is about right for most pagers. +/- 100 mS won't matter after the firmware update.
Joe M.
  #95 (permalink)
Old 07-13-2005, 7:42 AM
safetyobc's Avatar
I am a firefighter here in S. Arkansas. I got my tone out info from our radio programmers. Both tone freqs and durations and my tone out function does not work. I tried it a few times but have lost faith in it. Maybe the firmware upgrade will help make it work correctly. I set the durations as specified. It didn't work. I tried shortening one duration, then both durations....and still nothing.
  #96 (permalink)
Old 07-13-2005, 3:42 PM
Are you sure they gave you the right info?
What exactly did they give you for tones and timing?
Joe M.
  #97 (permalink)
Old 07-13-2005, 4:53 PM
safetyobc's Avatar
Yeah, he showed me on his laptop and wrote the info down for me, actually gave it to me twice because I lost the first one.
Freq: 154.9725
Tone A: 433.9
Tone A Duration: 1 second
Tone B: 330.9
Tone B Duration: 3 seconds
Tone Gap: 0 seconds
  #98 (permalink)
Old 07-13-2005, 6:24 PM
Those are not standard tones although they are close to the entries in Motorola Group 1. If you have the frequency set to NFM, try FM instead. If it still doesn't work, posting a wav recording of the tone out will allow someone here to analyze it.
  #99 (permalink)
Old 07-13-2005, 11:25 PM
Al42's Avatar
Freq: 154.9725
Tone A: 433.9
Tone B: 330.9
Tone Gap: 0 seconds
Try programming a gap of 1 ms. Just a thought.
  #100 (permalink)
Old 07-13-2005, 11:33 PM
troymail's Avatar
Freq: 154.9725
Tone A: 433.9
Tone B: 330.9
Tone Gap: 0 seconds
I believe this is a known problem. My local system also has NO gap (0) but the scanner firmware currently requires their be a gap of at least 1 ms. The Uniden firmware is supposed to fix this and other timing issues ... in fact the 396_UASD software doesn't asking for tone lengths of a gap length... but we're still waiting for the firmware.
