Go Back   The Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > Uniden Thread Archives
Old 06-26-2010, 8:35 PM
Default BCD996XT P25 wont lock on system
Has anyone had issues with the 996XT not locking on the control channel of a VHF P25 system? The unit works great on Motorola Type II P25 systems ( Beale AFB & Davis, CA PD) but won't lock onto Placer Counties new P25 system. It tries to lock on & I heard some intermittent conversations then the signal meter flashes & it looses the control channel. I used the same data file from a freinds 396XT & his works great on the same system. I also checked for any interference with my spectrum analyzer & found none. Any help would be appreciated. Steve
Old 06-27-2010, 12:22 AM
avtarsingh's Avatar
hopefully UPMAN sees this and can give some insight
seems to be a p25 decoding issue
he has played with the p25 settings all over the dial and cant get the system to decode p25
facts or assumptions?
Old 06-27-2010, 4:46 PM
It sounds like I am having similar problems, We recently switched to a 700 mHz P25 system here in Johnson County Kansas, I programmed some scanners with the info from scanner reference instead of entering it all manually. the issue I am having is the scanner can be holding on a talk group and I can have a motorola portable right next to the scanner and the portable will receive all of a transmission while the scanner some times will get it all, some time some of it and other times none of it. Is this a similar problem and if so please fill me in on the fix as well. Thanks!!
All information here is Copyright 2012 by LLC and Lindsay C. Blanton III.Ad Management by RedTyger
Copyright 2015 by LLC Privacy Policy  |  Terms and Conditions
