JCC419
Is there a way to enter a frequency manually in this scanner in case when you enter the zip code and a
particular frequency isn't there from the down load ?
The Advance Mode has an option called Quick Frequency Entry. It lets you enter in an individual single frequency.
Sheldon.
Not sure what you are saying. You can enter frequencies manually.
Hit "acccept" instead of "listen"
"Accept" does not come up as an option... Only "listen" & "back"
