Old 12-02-2010, 4:06 PM
JCC419's Avatar
Default Home Patrol Programing
Is there a way to enter a frequency manually in this scanner in case when you enter the zip code and a
particular frequency isn't there from the down load ?
Homepatrol
BC796D With digital card
BC785D With digital card
BC250D With digital card
Old 12-02-2010, 4:40 PM
se's Avatar
se se is offline
The Advance Mode has an option called Quick Frequency Entry. It lets you enter in an individual single frequency.
Sheldon.
Old 12-02-2010, 5:13 PM
Better bet is to submit that frequency to the RRDB.
Old 12-02-2010, 6:13 PM
you CANNOT PROGRAM the home patrol yourself, i do believe there is new software however where you can, http://www.scancat.com/Addendum_Home...canner.doc.pdf
Old 04-13-2012, 10:19 AM
Sheldon.
I found that, but there is no way to have it entered and listen to it. If you tap "listen" it puts you back to the stuff you where monitoring before.
Old 04-13-2012, 1:34 PM
Not sure what you are saying. You can enter frequencies manually.
Old 04-13-2012, 1:46 PM
Well, I was sitting near a "drive thru" and I wanted to try and pick up the wireless orders. I wanted to try some of the freq. that were listed online but I couldn't find out how to "listen"... I entered the freq. manually, then tapped the "Listen" button, but the scanner just went back to scanning the system that I was on before I tried the manual entry.
Hope that makes sense.... I must be missing a step some where
Old 04-13-2012, 1:47 PM
mciupa's Avatar
Forums Moderator
Just copy the Full Database into a Favorites List. You can then add what ever you like to that list after following a few steps that the HP will prompt you for.
I ran the numbers, honey. I CAN get that new scanner.
Old 04-13-2012, 5:22 PM
captaincraig44's Avatar
Hit "acccept" instead of "listen"
Craig Mills
Denver, CO
MNN //113//
Old 04-13-2012, 5:42 PM
"Accept" does not come up as an option... Only "listen" & "back"
Old 04-13-2012, 7:18 PM
mciupa's Avatar
Forums Moderator
You cannot modify or edit the Full Database.
If you want to add something you must work in a Favorite List.
Old 04-13-2012, 7:52 PM
Thanks my friends, i'll find out next time I play with my HP1
Old 04-13-2012, 10:41 PM
When you manually enter the frequency from the advanced options menu (I don't believe this is an Extreme only option?) - "Quick Frequency Entry", the third selection on the bottom from the left is "accept". Hit that. You're off and running.
Just to be clear - from the main menu -> Advanced Menu - > Quick Frequency Entry. Enter your selected freq, then, hit "Accept" on the bottom right.
Craig Mills
Denver, CO
MNN //113//
