Old 01-24-2011, 6:31 PM
Default Uniden HomePatrol Programming Question
Hello,
I know this is probably a stupid question... but, can a guy program in a system, talkgroup ID and site information if the Radio Reference site doesn't have it in the database. Furthermore, if a guy can, what is the BEST software to use to do so?
Thanks all!!
Old 01-24-2011, 7:00 PM
The simple answer is "yes". You can:
Add a frequency that is not in the built-in database
Add a talkgroup that is not in the built-in database
Add/Modify a control channel frequency
Add a trunk system that is not in the built-in database
Add Nascar and other race frequencies
Change Alpha tags
Change or add subtones
Add Airband, CB, Marine, Railroad, FRS and GMRS frequencies
Change the service type of frequencies and/or talkgroups
Search a frequency range
Butel has software available for HP-1. (I can't say it's the best). Perhaps others, too.
The most important things in life aren't things
Old 01-25-2011, 12:47 AM
911scanner's Avatar
The developer of Freescan has introduced PowerPatrol for the HP-1. It is a freeware program, and many people at RR, including myself feel Freescan is a wonderful editing tool.
ScanNow.org - The Home of FreeSCAN!
MM
Uniden SC-150, 780XLT, BC296D, 2x BCD396T, BCD396XT & HomePatrol 1 (plus various retired paperweights)
Old 01-25-2011, 7:42 PM
Thanks guys! Finally, if you had a choice of getting a HP-1 new or BCD996T new, which would you choose?
I'm on the fence...
Old 01-26-2011, 8:56 AM
911scanner's Avatar
I'm on the fence...
It would depend on how well you understand the Uniden DMA structure, or whether you are a bit of an electronics "nerd".
The "T" & "XT" series of scanners can do quite a few things, many of which the HP-1 cannot do. If you want to have a less complicated set-up, then HP-1 is the way to go.
I live in the Twin Cities, so I have a good idea of what you'll be able to listen to. I already have both the "T" & "XT" series units. From what I've heard, the HP-1 will have a bit better receive, so I'm personally excited to get my hands on the HomePatrol to see if this is the case. I know it will be easier to just listen straight out of the box.
MM
