N9NGF
I got tired of waiting for my Uniden programming cable, plus i was bored, so I built my own.
Note: This cable is for serial communication to your Uniden scanner only.
Do not try to connect the cable from Amazon directly to your scanner or it may be damaged.
I take no responsibilty for any of this info, proceed at your own risk.
This works with my BCD396XT, but should work with others that use the same cable.
Parts:
USB to Hirose connector cable. $0.99
Amazon.com: USB A to Mini-B 4-Pin Cable: 6 ft (Hirose/Single Notch) - by Abacus24-7: Electronics
DB9 Female connector $1.15
Amazon.com: Solder Cup D-Sub Connector, DB9 Female: Electronics
DB9 Hood $0.85
Amazon.com: Assembled D-Sub Hood Kit, DB9/HD15 Gray: Electronics
Cut off the rectangular USB connector and solder these wires to the female D-SUB connector.
You will also have a shield, I just cut it off, but you could solder it to the hood if you have a metal hood.
RED PIN 2 RXD
GRN PIN 3 TXD
BLK PIN 5 GND
WHT PIN 8 CTS
Parts:
DB9 Hood $0.85
RED PIN 2 RXD
GRN PIN 3 TXD
BLK PIN 5 GND
WHT PIN 8 CTS
