  #221 (permalink)
Old 07-25-2011, 10:17 PM
wise871's Avatar
b52hbuff, I remember the first time I bought a radio that offered UID. It was the Pro-197, before Uniden added the feature. This was the greatest feature to me since the invention of sliced bread. My first month was spent running Unitrunker and ID Tracker to ID each radio that was used by my local system (Pensacola 800). Within months I had compiled a very detailed listing. I was monitoring Pensacola so I would name the dispatches as Fire Dispatch, Police Dispatch, etc. Even when the dispatchers went from primary to tac-1 a new console UID would appear. The patrol units were PPD Unit 156, PPD CSI 400, etc. If they were a Sergeant I would add SGT to the alpha tag. You get the idea; my list was 99% accurate.
Then after a month I noticed that my UID were not matching up as they use too. Then it dawned on me that users were switching cars, radios, etc. I was bummed at first but then I started using a more generic naming system that still worked. Since dispatch consoles didnít change along with radios in fire vehicles, I started naming them like, PPD Patrol, PPD CID, etc so they would still reflect the user using the radio.
I still mess around with UID but mainly to ID those radios that donít change. Have fun with the new feature. Itís still a lot of fun.
Dan
Uniden:SDS100,BCD536HP,BCD996p2,HP-1/2e,BCD396XT,BCD996T(XT),BCT15X, BC898T
Radio Shack:PRO-197,PRO-106
Vintage:PRO-25,Sony Air-8
  #222 (permalink)
Old 07-26-2011, 12:49 AM
milcom_chaser's Avatar
Default Direct Entry...
UPman,
Great video. Being on Camera is not easy while trying to read. But having a visual is more personal.
With the extreme makeover, can we directly enter a freq. in the same manner as the 396XT?
Also, is Close Call something that is implemented via firmware or does it require other IC's to have this
feature in the HP-1?
Thanks for taking moment, no doubt you have plenty on your plate.
-L
  #223 (permalink)
Old 07-26-2011, 12:54 AM
My observation has been that b52hbuff, while very well meaning and extremely thorough with his posts, appears to believe that scanning begins and ends with the HomePatrol, and therefore the RR DB should bend and expand every which way to accommodate a single device among dozens. I've read most of his posts since he acquired his HomePatrol, and can draw no other conclusion. I've seen it explained to him dozens of times that the RR DB does not exist solely to support one device, namely the HomePatrol, but I'm not certain that fact has really sunk in yet.
Just to be clear, GRE has supported RID/UID since the 500/600 were released in 2007, a full 3 years before the HomePatrol was even released. The RR DB wasn't expanded back then to include RID/UID fields, so why should it be now?
The statement that the HomePatrol "has historically leveraged shared contributions from a knowledgeable user base" all by itself is a bit far reaching as well. The RR DB would not exist at all without years worth of contributions from a knowledgeable user base. Again, the bulk of it taking place before the HomePatrol came on the scene. Granted, the HomePatrol is (or was, prior to this Extreme Upgrade) probably the scanner most dependent on accurate RR DB info in order to work to its full potential.
I guess I'm just curious where all these suggestions were prior to the HomePatrol being released?
  #224 (permalink)
Old 07-26-2011, 1:10 AM
One thing none of us know is what kind of deal RR & Uniden have worked up and that could change everything, I believe the "HP-1 way" is the tip of the iceberg in the way scanning is to be..... Just my 2 cents..
  #225 (permalink)
Old 07-26-2011, 7:04 AM
jimboyle's Avatar
When will the update be finished ?
Now I see, mid August ! I can't wait !
Jim Boyle, Sergeant NC Department of Public Safety, State Capitol Police, KF4COP
  #226 (permalink)
Old 07-26-2011, 7:20 AM
Scroll back to the very first page.
  #227 (permalink)
Old 07-26-2011, 9:21 AM
You can never be for sure what is in a persons heart or mind. In fact after I write this note, you'll still not be sure...
Before the HP-1, I had (and still have) a variety of other radios. Most of my radios are Uniden DMA, a couple of GRE. All of those radios were programmed by me, using programs that didn't rely on the RR.com db. Part of my enjoyment was printing out the various frequency lists and arranging the data to match my personal preferences.
You're going to gravitate towards the UID discussion to highlight the independence of the RR.com db. I could highlight other discussions that the RR.com db has accomodated the HP-1 and various other Uniden radios. What other radios even support geotagging? What radios support rectangular geotags? What radios support the Description field?
You seem to understand why the questions are being asked now, so I don't see why you're posing the question again? The HP-1 derives a large part of it's 'value' based on the data that comes from this site. And all I did was ask a question about database support for RIDs. Once the point was made, I didn't go back and revisit the decision. The followups are simply enhancement requests (e.g. RID masking/ranges) or user-based ability/features to allow sharing outside of the database.
The reality is that there is a symbiotic relationship between the two entities. As Eric says here:
http://forums.radioreference.com/dat...ml#post1396721
I have confidence that the RRDB will continue to adapt as our hobby grows.
Adaptation, by its very nature is a slow process that involves compromise. Part of adaptation is having folks question what is going on...
One other post to note:
http://forums.radioreference.com/dat...ml#post1409780
So its not just me who is getting a new interest...
Anyway, if you want to call me out for 'special attention', I think we'd all appreciate it if you took it to a PM or to the Tavern...
  #228 (permalink)
Old 07-26-2011, 4:17 PM
Just purchased the Ext upgrade, received the key #, now just waiting.
Thanks Paul
  #229 (permalink)
Old 07-26-2011, 6:20 PM
Question Can someone help
The web site you are accessing has experienced an unexpected error.
Please contact the website administrator.
The following information is meant for the website developer for debugging purposes.
Error Occurred While Processing Request
Element ESNSUFFIX is undefined in FORM.
Resources:
Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debugging Settings, and select the Robust Exception Information option.
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
I enjoy hear about Scanners Info
  #230 (permalink)
Old 07-26-2011, 6:33 PM
KWs's Avatar
KWs KWs is offline
That website is so screwed up .. I received the confirmation, even though (after an hour with Uniden customer service) they determined there really was no authorized purchase .. so now I have to start over and HOPE the problem is fixed. They have no idea why I received the confirmation product purchase ID ... guess I'll just wait a while, see if they fix the web purchase page.
KWs
  #231 (permalink)
Old 07-27-2011, 10:50 AM
bgav's Avatar
Thanks UPMan for the news and video series, and to you and the team at Uniden for working hard to bring it to reality. I will be taking advantage of the pre-purchase discount.
Seriously, to those people complaining about the price of the upgrade, I suggest the following:
1. Price other "software defined" radios/receivers.
2. Those prices do not include the computer required to use them. A good percentage of users of software defined radios use them with a dedicated computer in their monitoring station to run 24X7 for logging, recording, traffic analysis, etc. The HP-1 is a standalone product utilizing a touch-screen display that you can program with an existing home computer or completely on the unit's touch screen display with the Extrem Edition upgrade.
3. Price other stand-alone scanners then add the cost of third-party software that is required for a number of the features that the HP-1E will have such as RF power plot, activity analysis, band scope, real-time trunked system analysis with logging, etc while scanning with no computer required. Yes, there are free alternatives out there that individually offer some of those features, but how about all of them?
I think you'll quickly see no other product out there right now offers the features of the HP-1(E) at a comparable value with such portability. I'm coming from the perspective of being a long-time user of an Optocom running Scan*Star Pro (with audio logger) on a laptop computer. The HP-1(E) will give me all of the features I had on the Optocom/Scan*Star and more, in a much more portable package that I can easily use around the house and transfer to my car and do location-based scanning with GPS.
In my opinion, even at full MSRP and full upgrade price for the Extreme Edition that's an excellent value proposition for those capabilities.
HP-1|PSR-800|BC780XLT|Pro-92 |Yaesu VX-6R
PlanePlotter Ground Station mH
  #232 (permalink)
Old 07-27-2011, 11:21 AM
adamr368's Avatar
Resources:
You need to go back into the my.uniden.com site, login, select "All Scanners" then enter the ESN of your scanner. The error you show is because the keygen can't locate your ESN within the registration area to generate your key.
  #233 (permalink)
Old 07-27-2011, 6:06 PM
DaveNF2G's Avatar
By following the instructions on the Uniden website and doing exactly and only what it said to do, I have successfully prepurchased my extreme upgrade.
David T. Stark
NF2G WQMY980 KYR7128
  #234 (permalink)
Old 07-27-2011, 6:59 PM
Me too. I had registered my HP-1 ESN a while ago. I just went to My Products page and clicked the Get Key link... Worked like a charm. Eagerly awaiting the update...
  #235 (permalink)
Old 07-28-2011, 1:21 AM
ICP963's Avatar
I am guessing that this error comes after he has received his key and is hitting the `UPDATE' button on that screen. I say that because I get the same error there. I am also guessing that this error is the because the file is not ready to be downloaded yet.
That is only a guess, but I am sure that Upman can elaborate on this.
Roy Schahrer ICP963
e-mail k8x815@cox.net
  #236 (permalink)
Old 07-28-2011, 7:07 AM
UPMan's Avatar
Uniden Representative
Anyone still experiencing a purchase issue should report it in the forums at HomePatrol (I don't make it a habit to send people out of these fine forums for help, but our customer service group only continuously monitors those forums...and we only have the ability to see users email addresses in those forums for private followup). As far as we know, fewer than a dozen people had a purchase issue (and 8 of those were due to typos in the credit card information).
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
  #237 (permalink)
Old 07-28-2011, 8:07 AM
hamstang's Avatar
Amazing how so many customer service issues are actually the customer's fault! Yes, I know, the customer is always right. I am eagerly awaiting my prepurchased Extreme upgrade.
  #238 (permalink)
Old 07-28-2011, 9:02 AM
UPMan's Avatar
Nope, we should have trapped for the error.
Personal Blog
  #239 (permalink)
Old 07-28-2011, 10:55 AM
KWs's Avatar
KWs KWs is offline
3rd time was a charm .. successfully purchased my upgrade key.
KWs
  #240 (permalink)
Old 07-29-2011, 8:35 AM
scottct1's Avatar
Go mine ordered!
Scott
SatelliteGuys.US
MultiChannel News
