Having problem with Virtual control on ARCPatrol. It shows the the control,radio scans but I cannot do anything else. It is connected to comport 5. The display shows the radio on the top and bottom menu bars it does not show the same as on the HP1 itself. The top bar only has, "ATTEN" in the center and "BUSY" in the right corner. It does not show SQUELCH, RANGE, GPS or HELP menus. The bottom menu bar only shows "AUTO" in the left corner. No MENU, REPLAY, RECORD or MUTE controls. It does let me lock the Department,Channel etc. When I click the red, orange or yellow arrow tabs on the side it only displays those options on the unit itself and not the computer, so I have to go back and forth between the HP1 and computer to control. I tried changing the port setting and still the same result. I tried to copy a screen shot but no luck. If anyone has the answer please let me know. I also posted this in the POST RELEASE thread and have not found the answer. If anyone has other or similar problems even answers, please feel free to post in this thread so everyone can gain.
Thanks, bigbear518
Thanks, bigbear518
