  #321 (permalink)
Old 04-08-2012, 12:21 AM
Originally Posted by a1emt View Post
Never had a problem with Uniden firmware updates til this evening. While upgrading my BCD996xt, the process errored out so I tried to apply the update again by starting over from step one. However, now the radio does not seem to power up (no backlight) and will not communicate with my PC. Tested the cable with another radio and re-downloaded the firmware file to no avail. Also tried the 2+9+L/O hard reset.
Anyone run into this before?
Jim
Do as DDan said and start from step 1 a few times.
The lack of the blue backlight does sound odd though. I thought I saw a thread that indicated the backlight would still power up but in a blank blue color if stuck from a failed FW update.
Can you use another power source like the cig lighter power adapter just to rule out the power adapter?
Or the three wire adapter hooked to a 12 volt battery as that would also rule out the coaxial power jack as the cause of a problem.
Even though the radio does not communicate, try and run the updater again after starting over from step 1 even with the blank screen.
  #322 (permalink)
Old 04-10-2012, 8:17 PM
r u using the front or rear input ? ( use front ) have u updated another uniden scanner souch as a bcd996Twitch would try 2 load the wrong update. go to control panel, systems,my hardware,device manager,com ports to c if ur scanner is listed
  #323 (permalink)
Old 04-11-2012, 8:05 AM
I updated my 396XT without any problems. But I did not check "Enable Major Version Up". Did I need to do that?
  #324 (permalink)
Old 04-11-2012, 8:48 AM
I didn't. Mine works fine.
Relm HS200, BCD396XT, HP-1E, BCD436HP, BCD536HP, BCD325P2
  #325 (permalink)
Old 04-11-2012, 4:23 PM
UPMan's Avatar
Uniden Representative
You only need to check that box when you are doing a major version up (i.e. the first digit increments).
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
  #326 (permalink)
Old 04-11-2012, 6:20 PM
i believe u may have updated ur 996xt with a 396xt update witch r not the same.here is what i would do.create a folder in my docs named 996XT. go to unidens web site and download firmware updates to the folder 996XT instead of to ur desk top. after u down load BC VUP V2.0.0.7.zip and v1.06.00 un zip these files to ur 996XT folder. now try to update ur scanner by 996XT folder in stead of ur desk top. b sure that u r in ur 996XT folder via the drop down menu. hope this helps i had a simular problem with a bcd996t and it worked 4 me
nailech
do not check enable major version
  #327 (permalink)
Old 04-11-2012, 11:31 PM
Thanks to everyone who replied to my question. I feel better knowing I didn't need to check that box.
  #328 (permalink)
Old 04-13-2012, 6:50 PM
Cool Low Pass Filter for P25
I just picked up a 996XT for my mobile environment (upgrade from old BCT15.)
After programming I noticed that I had the LP filter turned off for P25.
Is this suppose to be on or off? I'm not sure if I have ever been using it, to be honest. My 396XT seems fine so I'm wondering if this is still a valid setting with the new firmware upgrade?
  #329 (permalink)
Old 04-13-2012, 6:57 PM
scanningisfun's Avatar
It is a filter that removes a high pitched tone that goes along with P25 audio on some systems. It supposedly can decrease decode performance, but I haven't had any problems.
Here is someone else's video you can hear the distinct high pitched tone on:
Connecticut State Police Uniden Bearcat bcd396t scanner - YouTube
Here is my 396XT with the LP filter turned on; this is the same system as the first video:
BCD396XT Scanning w/New Firmware - YouTube
Jacob
Jacob
  #330 (permalink)
Old 04-13-2012, 6:58 PM
W6KRU's Avatar
It should be turned on only if you need it. See this link: Easier to Read BCD996XT Digital Scanner Manual
73 de W6KRU - Dan
WS-1080 PSR-500 BCD436HP BCD396XT BCD396T FRG-100 PRO-43 PRO-90 PRO-2050 FT-857 FT-90 VX-170 VX-3
  #331 (permalink)
Old 04-13-2012, 8:15 PM
Cool
Jacob
Okay thanks for the samples. Yeah I recall hearing that noise on one system but can't remember which. It seems fine without it so that's good to know.
  #332 (permalink)
Old 04-14-2012, 10:48 AM
Cool p25 filter
i think it depends on the p25 system that you are monitoring. i have mine switched to off on warrs p25 system middle west ga.
  #333 (permalink)
Old 04-17-2012, 1:58 PM
yepme2's Avatar
started the upgrade showed about 2/3 complete and hung at that point shut scanner down after 30 mins
started over on square 1 held l/o plus 6 while power on scanner display was blank and not lit. update program came back with communicator error. what next?
  #334 (permalink)
Old 04-17-2012, 2:46 PM
UPMan's Avatar
Check your connections. Repeat the upgrade process. There is not way to permanently brick the scanner by doing an update.
You'll find more tips based on the specific error message you received here: http://wiki.radioreference.com/index...rmware_Upgrade
Personal Blog
  #335 (permalink)
Old 04-17-2012, 5:26 PM
do u no what com port ur pc is using to communicate with ur scanner ?
  #336 (permalink)
Old 04-17-2012, 5:53 PM
yepme2's Avatar
com4. USB not the problem it updated about half way then stopped now I cannot even turn it on..
no lcd display and no backlite..12v power is good..USB cable is good
  #337 (permalink)
Old 04-17-2012, 6:37 PM
UPMan's Avatar
You need to restart from step 1, following all instructions, including when it tells you to power up while holding down the keys. Since the main firmware is broken, it isn't going to power normally (but the bootstrap code used for firmware updating is never touched, so the update process can be redone to fix the issue).
Personal Blog
  #338 (permalink)
Old 04-17-2012, 6:59 PM
try holding down function and 1 key at the same time while powering on scanner for a system configuration check
  #339 (permalink)
Old 04-18-2012, 8:40 AM
yepme2's Avatar
the grass is green and the birds are singing...I finely got a blue screen an updated 6 times each time it would advance a little further until finished ...Thanks for all the help.....
  #340 (permalink)
Old 04-29-2012, 8:36 PM
Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 5_1 like Mac OS X) AppleWebKit/534.46 (KHTML, like Gecko) Version/5.1 Mobile/9B176 Safari/7534.48.3)
Anyone seeing a problem with keypad when trunking? Just did update on 396xt and keypad would only work when a talk group was active. When no tg activity I could not do anything with keypad (was not locked). Things are fine in conventional systems. It was acting like it was working so hard at decoding it won't do anything else-I used the recommended settings and had no problems with firmware updating
Well, I just found my answer, had set baud rate to 4800 to communicate with my gps. I changed baud rate to 57600 and not having any issues. I have not updated 996xt and did not have same issue when down at 4800. Upman is this maybe a bug or something logical?
