Old 05-24-2012, 2:09 PM
Default bc235xlt
help program bc235xlt uhf trunk
Old 05-24-2012, 2:14 PM
Wiki Admin Emeritus
This is the wrong forum, but I'll answer this - can't be done. The 235 is a first gen trunking scanner that could only do 800 Mhz analog Motorola trunking, and only that or conventional scanning - not both at the same time
Old 05-24-2012, 2:59 PM
scannerfreak's Avatar
Moderator
joerobb23, please do not hijack another thread with your (off topic) question. Please start your own thread in the appropriate forum.
Forum Rules and Guidelines
Old 05-25-2012, 11:27 AM
Default forum & bc235xlt
sorry for the wrong forum where should i have poste first post & also uniden techs & manual indicated 470 -512 t band is that not trunk? Thanks in advance sorry for post
Old 05-25-2012, 12:13 PM
Wiki Admin Emeritus
Questions about Uniden scanners can generally be put here - we have separate forums for each state as well as programming software.
Just because it covers that frequency range doesn't mean that it will trunk in them. At the time this radio came out, trunking as an industry was just getting more or less off the ground, and UHF trunking simply didn't exist in many places as yet. So the necessary instructions for the firmware on the scanner couldn't be developed.
Happily there are many 2nd generation and later trunktrackers that will handle this mode now, but nothing back as early as that 235
HTH...Mike
Old 07-25-2012, 4:20 PM
another question sorry if wrong forum programmed new jersey state police into bc235xlt no response from scanner channels programmed but would rebanding prevent response from scanner?
Old 07-25-2012, 4:29 PM
N8IAA's Avatar
Yes. And the 245 won't reband either. The 346 is the latest analog trunking scanner that Uniden makes.
HTH,
Larry
