SentinelVT
I am currently running a BCT15 for one of the live feeds on this website and am experiencing a constant beeping noise in the background. This occurs when there are no transmissions and during transmissions. I have been trying to diagnose what is it over the past few days, however have had no luck. Hopefully someone here will have an idea of what is going on. You can listen to the feed in the live audio section, under Maine, Cumberland County. The feed is titled "Cape Elizabeth Fire and EMS Dispatch."
I have tried swapping power cables, audio cables, computer inputs, and many other things. At this point I am fairly certain that the issue is with the scanner itself. I upgraded the firmware last night to make sure that it had the latest and greatest. I also tried swapping the audio cable between the ext speaker port and the headphone jack with no relief. I have BCT15X running as well for another feed and I have had no problems with that at all. The audio is completely silent until something is said on the scanned frequencies.
If anyone has a possible solution, I am willing to try it.
Thanks!
Alex
Thanks!
Alex
