Old 09-06-2012, 11:10 PM
Thumbs down Homepatrol 1 GPS plug
Is the plug for the gps unit on the homepatrol 1 soldered in or is it just plugged in? I only ask because I had the plug inside of the homepatrol 1 fell out when the cord was accidently pulled out. I put it back in and amazingly the gps still works. I only ask to figure out if I need to send it in to be repaired. Unfortunaltly the warranty is up. Any idea on how much a fix for that is?
Old 09-07-2012, 8:04 AM
bee bee is offline
I am also interested in the answer, to this question.
Old 09-07-2012, 8:52 AM
I had the same thing happen to mine, wound up sending in under warranty. No big deal, until it happened a second time, now it is not under warranty.
Kenny
Old 09-09-2012, 10:42 PM
I don't know how mine is working since it fell out of the scanner it's self. I don't know if I should send it in to be properly repaired or do I consider myself lucky that it is still working. Has anyone else experienced this problem and how they handled it.
Old 09-11-2012, 3:52 PM
I don't have one, wish I did and am not sure how the plug is attched, but anyone who does not have some "JB Weld" epoxy (the two part with one part gray, the other a very drk brown, be sure to get the right stuff, Hardware store etc) is missing out on some great stuff. If it's possible to just put a little JB on it, that plug will still be there long after the radio is dead.
Don't know if that helped any, but if so, you have a fix that will be timeless.
John
Old 09-11-2012, 5:32 PM
dkf435's Avatar
The GPS plug is a 4 pin USB type plug used on many digital cameras, when my plug broke, I called Uniden up and tried to get a plug. They replied that they did not sell internal componets for their radios??? So screw Uniden parts, found jacks on EBAY the one I found were better quality and are surface mounted with 2 plastic index pins.
Hirose Elec. MQ172X-4PA(66) 4POS SMT Conn
Ebay auction (3) Hirose Elec. MQ172X-4PA(66) 4POS SMT Conn., Recept. | eBay
You will need to be able to solder pretty good and not get too much solder that you short the pins together, they are not putting enough paste on these at manufacture for this many to be popping off. Some adhesive over the jack bonding it to the board helps also.
David Kb7uns
UNIDEN PARTS STILL SUCKS
AR3000,5000,8000,8200,8600,SDU5000,5500,ARD25R1,10 ,20,71,72,75,7000,7100,8500,PC/R100,1000,2500 PSR500,600,800,PRO668,2035,96,106,BC760,796,996T,9 96XT,396T,396XT,HP1,HP2,436HP,536HP,WH-TRX1
Old 09-19-2012, 8:47 PM
Sorry, I have not had the time to respond to you're answer. That is good to know that uniden doesn't carry a replacement part for the gps plug in. I have not tried to glue the part back in, but plugging it back in has worked wonderfully. I just wonder how common this problem is with the homepatrol.
Old 04-16-2013, 9:39 PM
BobW55's Avatar
Mine is gotten lose already as well,
Still under warranty, but may just re solder it on my own.
Be much quicker that way.
Old 06-15-2013, 11:14 AM
del1964's Avatar
Default Homepatrol 1 GPS plug
My GPS plug pulled out of the Home Patrol also. I disassembled the unit and found out it has 4 tabs that are suppose to be soldered down. All 4 tabs broke from this solder connection. I attempted to resolved them down but it's like micro soldering that's required. Tiny tiny tiny and extremely close together. Very very easy to short between these tabs. Just can't see what you're doing. Need a microscope. I tried using magnifying app on my Iphone 5 but ..... Hard to see. I "thought" maybe I had fixed it but after reassembly, everything worked fine except for the GPS. so apparently either shorted across or an incomplete solder joint on one or more of the 4 tabs
http://www.broadcastify.com/listen/feed/3666
Uniden BCD396XT & Home Patrol II. WHISTLER TRX-1. AIRSPY. RTL-SDR. Unitrunker. DSD+.
Old 06-15-2013, 11:15 AM
del1964's Avatar
Re solder. Not resolved. Auto correct
Old 06-17-2013, 6:21 AM
ST-Bob's Avatar
You probably should have edited your post, not posted a correction. This is not a text-message...
It's a real-estate problem on the board. There's simply not enough room for a full-sized DB-9 connector in the HomePatrol's design. Unfortunately, you're stuck with the design and the microscopic repair needed to fix it once broken off the board.
The connector's contacts are soldered like surface-mounted devices using solder paste and a hot air source, not a soldering iron. The connector shell is further soldered to the board but should really have glue holding it to the printed circuit board in addition to the solder-paste in my opinion.
Best bet is probably to send it back to Uniden for repair or replacement of the main board, unfortunately.
Bob Peloquin - KB1VUA
Uniden HomePatrol-1, BCD536HP
Old 06-17-2013, 11:50 AM
dkf435's Avatar
Jacks on eBay for sale, not hard job just have good solder station and solder wick with flux and flux remover on hand.
3 Hirose Elec MQ172X 4PA 66 4POS SMT Conn Recept | eBay
David Kb7uns
Old 12-09-2013, 6:00 PM
del1964's Avatar
Mine broke off.
Old 12-09-2013, 6:44 PM
ST-Bob's Avatar
As you can see from this thread (and over on homepatrol.com) it's a fairly common problem with the design. The socket is hot-air soldered to the top of the board and has a fairly weak physical connection to it as a result.
The 4 pins are on 0.5mm spacing which requires a really fine-tipped soldering iron, a steady hand and a strong magnifier to work on it with any success. Unless you have the skills and tools for the job I'd suggest sending in to Uniden for repair rather than screwing it up further yourself.
Bob - KB1VUA
Old 02-07-2014, 7:12 PM
del1964's Avatar
Really the only reason I sold my Home Patrol. Major design flaw for it to break connection so easily. And that's THE major reason IMO to have the Home patrol.....GPS location and automatic downloading of frequencies you're driving into
Old 02-07-2014, 10:22 PM
dkf435's Avatar
I really wish that a 4 conductor 1/8 mini jack could be put in there, lot better connection and about the same space.
David Kb7uns
