Old 10-28-2012, 12:28 PM
Default Lake County,Oh
Hi,I have BCD396T and no longer can listen to Lake County,Oh anymore. the last time I listened was this winter. It looks like they may have done something in April.
Thanks Dan
Old 10-28-2012, 1:07 PM
Thanks Dan
I am not sure what you had programmed into your scanner before but they may have changed frequencies, rebanded or joined MARCS. But here is a link (below) that I found but not sure if this will help you or not. I'm sure some one will be able to help you out on this forum.
Ohio MARCS-IP: Multi-Agency Radio Communications (P25) Trunking System, Various, Ohio - Scanner Frequencies
Good luck.
Randy
N8WRW WQYT375 SKYWARN SPOTTER
RS Pro 2052 Pro 94 (2) ICOM 3230A 2m/440 Kenwood TH-F6 Wouxon KG-UV3D Motorola GP68 President HR2510 10 meter TYT 7800 ICOM-718 Yaesu FT-890 GT-5TP
Old 10-28-2012, 1:34 PM
Thanks,I downloaded the currant info this morning but still nothing.I can listen on my phone and online.
I just wanted to be prepared for Frankenstorm.
Dan
Old 10-28-2012, 1:58 PM
n4yek's Avatar
Post #43 in this thread:
http://forums.radioreference.com/ohi...-2011-a-3.html
States that they moved to the MARCS P25 X2-TDMA system.
If you want to continue scanning it, you need a GRE PSR-800.
Danny
A blood donor saved my life (Matthew 26:28)
If 'con' is opposite of 'pro', is Congress the opposite of progress?
Old 10-28-2012, 2:47 PM
davidzimmerman's Avatar
Default lake county
try these control channels
855.8625
860.7625
860.8125
860.8625
i have the GRE-800 and BCD396XT scanner they both work on lake countys system just use the 800MHZ control channels you must use the new talkgroups the old ones will not work so go look at the data page for this system.
Old 10-28-2012, 3:39 PM
FYI: To date there are no reports of X2 or Phase II TDMA transmissions. I monitor the system with a GRE PSR-500.
Why is the system listed as X2-TDMA? Because the system was deployed with the latest hardware/software versions of Moto Astro which are X2 capable.
Bud
Pro-34/Pro-97/PSR-500/BCD436HP/TRX-1
Old 10-28-2012, 7:17 PM
Is there a differance between the t and the xt? Maybe my BCD396T will not work anymore.The last time I used it was in the winter this year.I still get Geauga County.
Old 10-29-2012, 8:11 AM
Rt169Radio's Avatar
Check out this link about the BCD396XT, the words in bold are the new features compared to the BCD396T.
http://wiki.radioreference.com/index.php/BCD396XT
Old 10-30-2012, 9:18 AM
It looks like I need a currant control channel,it does not seem to have the correct one.I downloaded the info of the website last nite but still looks for a control channel
Old 10-30-2012, 9:45 AM
Default Lake County
Lake County is now on the MARCS-IP P25 system. They have shutdown their Moto Type II system.
You will need to setup or download the new Lake County MARCS-IP P25 system.
Here are the differences, Project 25 Trunking vs Moto Type II, All new TG (Talk Groups), New Control Channels.
So just changing the control channels on the old system setup won't work.
Bud
Old 10-30-2012, 9:46 AM
Arrow
You are located near Lake County Ohio right?
Check in the Ohio Forum. There are people receiving this system.
Old 10-30-2012, 10:12 AM
mtindor's Avatar
OH/WV DB Admin
The old Type II system is completely off the air at this time? How long after they switched to MARCS-IP did they take down the old system?
Mike / AA8IA
PSR500/PRO197/BCD436HP/TRX-1
Email: my username @gmail
Old 10-30-2012, 11:41 AM
I guess I will have to wait for Radio Reference update there Lake County site.
Thanks Dan
Old 10-30-2012, 11:55 AM
Thanks Dan
Well it's there listed under the MARCS IP P25 site, not under Lake County's old site, which remains in the DB.
Old 10-30-2012, 12:55 PM
thanks,been a little busy
Old 10-30-2012, 4:12 PM
Smile
Thanks for everyones help,I am up and running.
dan
Old 11-25-2012, 1:11 PM
Default Lake County X2TDMA
I understand that they're not using the encryption yet, but for those who feel like they're left out of the new Lake County system, my old Pro96 still does the job.
I feel as though a PSR800 is in my not-to-distant future though as I work in Cuyahoga county and travel through Geauga down to Portage all the time.
