So here's my problem.
Purchased a very used BC296D without APCO card on ebay. I cleaned it up put a few conventional vhf frequencies in it and it picked them up fine. Figured I'd try it's ability to track my local simulcast system. I was told prior that a BCi25 card would work in a 296 or 796. I have a few "extra" cards laying around so I cleared the scanner put in a card and programmed the system. I programmed every frequency for the system and two very busy TGs. I set the CTCSS to CSQ and not search which I've heard causes some issues. I adjusted the audio settings numerous times. Still no decode when using the BCi25 cards. I made sure the settings had the card turned on, all the frequencies were programmed for trunking and P25. Just to rule it out I put my i96 card in it and it tracked it just fine. Any thoughts on a programming/setting that I'm missing and or an update to the i25 cards that I may need to update? The scanner itself is updated to latest firmware. Just for reference I searched the whole BCi25 vs BCi96 topic and found this which confirms the ability to use either card in either scanner(s)
http://forums.radioreference.com/uniden-scanners/167646-bci25d-v-bci96d.html
I'd like to add that when I have a BCi25 card in and am cycling through the audio quality settings I sometimes get traffic and it's clear but it goes away. Almost like I'm not getting proper decode. Note that none of my other scanners have issues with this system on stock antennas in same local. It also cycles the words P25 and ENC. Feels to me like it's acting like a 250 (not handling the 9600 baud CC)
system i'm monitoring:
http://www.radioreference.com/apps/db/?sid=2324
