Old 03-27-2013, 12:48 AM
Default Record Out & Streaming ??'s
I currently stream a stereo feed on here. The current setup has the audio being routed out of the back of the "Record Out" Jack on the back of the 996 and 15x. My question is the audio volume that is fed out of the record out controlled by the volume knob or is it constantly the same audio level?
North Jersey BC 996XT | BC 996P2 | 3 X BCT 15X | WHISTLER TRX - 1 | WHISTLER TRX - 2 | BC 346XT | BC 780XLT | 3 X BC 355 | RS Pro 405 | Pro 135 | PRO 2050
Old 03-27-2013, 1:17 AM
zl2taw's Avatar
have turned the volume knob to see if it adjusts the output volume ?
by the time you had posted here, you would have found out
73's Doug
Kenwood R-5000 / Elad FDM-S1 SDR / Wellbrook ALA-1530 / various software decoders
Brisbane, Australia, UTC+10
Old 03-27-2013, 2:43 AM
Tweekerbob's Avatar
It's at a constant level. In fact, the Speaker is still live when the REC OUT jack is being used, so the volume knob controls the speaker level.
I'm OCD with ADD. Everything's gotta be perfect...just for a little bit.
Old 03-27-2013, 3:49 AM
alwayslookin's Avatar
I have a question about this? I have a feed here as well and want to be able to use the rec out to run my feed so if I have to turn down the volume it won't affect the listeners. Do I have to check the record option in Proscan on what I want everyone to hear? I tried using it that way and listened to the live feed but did not hear anything on the feed but heard on the scanner itself also while trying this I was using my client side of Proscan and did not get any audio from it as well. Any advise? Thanks.
Old 03-27-2013, 10:59 AM
scosgt's Avatar
I find that I get better audio out for streaming using the headphone jack on front.
Old 03-27-2013, 2:02 PM
Im trying to run my feed with a constant volume for feed and be able to turn my volume down if need to with out affecting my feed. I tried the headphone as well still same issue.
Old 03-27-2013, 5:24 PM
scosgt's Avatar
Use one jack for the feed and the other for an amplified speaker like the one Radio Shack sells. Control the volume from the speaker.
Old 03-27-2013, 5:41 PM
Which jack I tried all of them and they all do the same when I turn the volume down on the scanner the volume for the feed goes down as well?
Old 03-27-2013, 6:15 PM
scosgt's Avatar
The record out jack on mine is not affected by the volume control. In ANY event, stream from the headphone jack on front. Set up your volume for streaming, then plug the amplified speaker into the rear ext speaker jack and leave the volume knob alone, just control the local volume on the speaker itself. Most all amplified speakers have a volume switch.
Tags
record out, stereo feed, streaming, uniden
