scanningisfun
- Joined
- Jun 29, 2010
- Messages
- 685
Why wouldn't the current digital scanners have an option set a specific alert whenever an emergency button is pressed. Yes, I know on Motorola Type II systems you are able to, but that is because the actual talkgroup is shifted whenever it is in emergency status. The scanner can see this and alerts you if you have it set up to do that.
On full P25 systems, you cannot do this. Why wouldn't Uniden take advantage of this on full P25 systems, or even conventional P25 channels? If an emergency bit is there, why wouldn't you be able to set an alert on those types of systems too? Would a firmware update add that capability? It is not a real deal breaker, but it would enhance the scanner.
Jacob
Jacob
